Tractor Talk Discussion Forum
update on the detroit diesel
D17 man
12-23-2006 16:13:11
i called the owner of the truck but he didnt know what it meant when i asked if it was a 2 cycle detroit or not. however he did say it has a turbo. does this mean it is a 2 cycle or did they make the 8.2 with a turbo also? and its a 1980 gmc 7000
ncdiesel48
12-24-2006 07:38:20
 Re: update on the detroit diesel in reply to D17 man, 12-23-2006 16:13:11
6 and 8 92's have a turbo and blower.
buickanddeere
12-23-2006 16:57:39
Two stroke Detroits were sometimes fitted with turbo's and they often had by-pass doors in the blower.
sdloy
12-23-2006 16:38:16
In that age of truck you could get both an 8.2 detroit and a 453t detroit. The 8.2 is a 4 stroke v8 engine and the 453t is a 2 stroke inline 4 cylinder. Hopefully he can tell the difference or can look at the spec label pasted in the glove box. Loy
Gene Davis (GA)
12-23-2006 20:14:16
 Re: update on the detroit diesel in reply to sdloy, 12-23-2006 16:38:16
Did some hauling of cars for a friend who runs a salvage company a few years back and drove a GMC straight truck for him with a car hauler body that was a back and over the cab type. Engine was a 4-53 that had both a blower and a turbo on it. He bought it out of Florida from a lady whose husband had special ordered the truck from somewhere and used it for a couple of years before he died. It was the first and only one I have ever seen with a blower on one side and turbo on the other side of the engine. The other guy hauling was running one of the big IH V-8 engine around 500 CID and we both had 5 sp trans + 2 speed rear ends. I could keep up with him, but you had to continually change gears and when in town you felt like you were rowing it you changed gears so often. It burned 1/3 less fuel than the IH did.
Bob
12-23-2006 16:27:52
If it REALLY is 8.2 liters, it is an "8.2 Liter Fuel Pincher Diesel".
They are 4-cycle, and were made in both turbo and naturally-aspirated versions.
I've linked a site below, that has some information.
workhorse
12-23-2006 18:00:58
 Re: update on the detroit diesel in reply to Bob, 12-23-2006 16:27:52
Look on the ground under the motor, If it's a 2cycle 453 there will be oil there.
Ultradog MN
12-23-2006 18:28:19
 Re: update on the detroit diesel in reply to workhorse, 12-23-2006 18:00:58
Good One Workhorse.
I was thinking about those Deetroits since the subject came up this week.
I'll bet some of the reason they went away was because there were a LOT of parts in those engines. Didn't they have a pretty complicated valve train?
And those blowers must have been an expensive item to manufacture.
thejdman01
12-23-2006 19:14:32
 Re: update on the detroit diesel in reply to Ultradog MN, 12-23-2006 18:28:19
Detroits were screaming gutless junk. Id take a 855 over a 8v92 any day of the week. Noise emissions and the oil leaks would definitly stop them today.
Ultradog MN
12-23-2006 19:23:25
 Re: update on the detroit diesel in reply to thejdman01, 12-23-2006 19:14:32
The company also had a bunch of Shiney 290 Cummins.
The Deetroit was definately more fun to drive.
Bob
12-23-2006 18:09:53
LOL... That's FUNNY!
