Tractor Talk Discussion Forum
Thermo-King
jc
12-25-2006 17:33:22
A few posts ago the discussion was on the engines for these units. I had the bright idea that the complete unit could be used to cool a shop in the summer. Is this fesible or would fuel cost make it prohibitive? Thanks in advance for your opinion and ideas.
T_Bone
12-26-2006 06:15:04
 Re: Thermo-King in reply to jc, 12-25-2006 17:33:22
Hi jc,
Without running alot of hard numbers, can it be used ? Yes
Will it be cost effective? Nope and won't even come close to a generator running a AC unit in most cases. Home made biodiesel might come close to fuel cost of a generator/AC but would depend on how many parts you need to buy to make the TK workable for AC use.
Do you have well/stream water avialable? A small circulating pump thru a AC coil along with a forced air fan will produce AC like air for a cheap cost, that is as cheap as AC costs.
Another is freeze blocks of ice at another location to add to a chilled water tank, then use the above to achieve cooling. A Ice water bath is a constant 32ºF.
T_Bone
Rick Reed
12-26-2006 03:14:49
I suppose it would work ok, but those things are terribly noisy. Just my opinion. I repair them for a living.
doogdoog
12-26-2006 00:26:39
Aloha, First you would have to know the specs of the unit before anything can be done. Yes, it could be done if it were in specs of the unit.
Mahalo,
doogdoog
Jon Hagen
12-25-2006 21:46:46
It would work fine,I have seen one used to cool an office with the diesel replaced with an electric motor. If running big amp power for an electric motor to the shop would be a problem,then it would run quite cheap on off road dieselfuel. Many reefers are made to work as a cooler or heat pump at the flick of a switch. They would keep the cargo cold when above freezing,or reverse as a heat pump to keep it from freezing in very cold weather. With the right thermostat it would maintain any temp you desired.
NEsota
12-25-2006 21:09:22
Many years ago here in Minneapolis, home of Thermo-King, a unit was being used to cool a large office building. After a long weekend people returned to work and found that ink had frozen, broken the glass jars and made quite a mess.
marlowe
12-25-2006 19:21:30
i use one to heat my shop in winter. i gut it out but keep the coil in it and run hot water from my outdoor wood stove also had to put in a elec motor to run the blower man dose it heat
old
12-25-2006 19:04:53
Don't think it would work well for that since its either a freezer unit or a unit made to cool things down to around 35-40 degress so if you used it to cool a shop it wouldn't be working as if should and would either cool to much or burn its self out doing the job.
iowa_tire_guy
12-25-2006 18:53:35
Don't know about fuel costs but I saw where a guy used one to cool a small building where they hung and stored their deer meat.
