Tractor Talk Discussion Forum
stanadyne db2 ip ??s
mike jenezon
12-25-2006 18:00:03
got bored today so i disassemled the dead pump off my 6.9 diesel (quit going down the road one night )black rings all broke up so when you replace the ring is it just the plastic ring you need to replace or do you have to replace the whole governor cage found a kit for about $35 and thinking about fixing it and having a spare pump any info would be helpful thanks mike
jdemaris
12-25-2006 18:19:54
 Re: stanadyne db2 ip ??s in reply to mike jenezon, 12-25-2006 18:00:03
You can just replace the old ring with the new composition pellathane ring - but it's usually eliminated and updated with the new sytle EID retainer. Just about all DB2 pumps came with the newer retainer assembly after mid-1985. The new style elastomer insert drive (EID) adds another $30 to the job. The seal kit itself is usually $20. In regard to the original style ring - like what failed - Stanadyne changed the material in it a couple of times in attempts to make it last longer - before giving up on it for automotive use. The ring you get now is supposed to last longer than the orignal "elasticast" rings. I'd guess 5-10 years. For me - I alsways put the EID in - it's well worth the $30.
B-maniac
12-26-2006 19:55:23
 Re: stanadyne db2 ip ??s in reply to jdemaris, 12-25-2006 18:19:54
Also make sure and clean all the granules out of the fuel return fitting or it still won't run when you put it back together.
