Tractor Talk Discussion Forum
Bearings in a 240U
Darin in Nebras
12-26-2006 09:56:07
Hello guys and gals, I have an International 240U with a gas burner in it. The main bearings and rod bearings need to be replaced. The crank needs to be ground. So the question is, do I have to split the tractor to pull the crank out or does it weg itself out somehow? Thanks for the input.
Thanks Darin
Darin in Nebraska
12-26-2006 11:59:26
 Re: Bearings in a 240U in reply to Darin in Nebraska, 12-26-2006 09:56:07
Thanks for the input. Thats what I was afraid of. Thanks
Glen in TX
12-26-2006 11:54:12
You'll need to purchase yourself something like a I and T shop manual for it.
Bob
12-26-2006 11:14:11
Besides the fact you HAVE to remove the engine to get the crank out, you would want to, anyway, to get the block boiled out and the oil galleries thoroughly cleaned, since there was bearing failure.
ejr-IA.
12-26-2006 10:18:10
You will have to split and pull the engine.
