Tractor Talk Discussion Forum
H -M WIDE FRONT END
T. H. RED
12-26-2006 14:47:52
I AM LOOKING FOR SOMEONE WHO KNOWS RED TRACTORS (IH) AND COULD TELL ME IF THERE ARE ANY CONVERSION HUBS THAT WOULD FIT WHERE THE OLD THREE SPOKE CAST RING HUBS THAT ARE ON THERE NOW, I WOULD LIKE TO PUT A SMALL LOADER ON MY TRACTOR AND WANT TO UPGRADE THE HUBS TO AN IMPLEMENT STYLE 6-8 BOLT HUB. ANY BODY GOT A CLUE?? GO RED THANKS FOR YOUR TIME T.H.
Jim J
12-26-2006 16:00:44
 Re: H -M WIDE FRONT END in reply to T. H. RED, 12-26-2006 14:47:52
I have a set of 6 bolt hubs for a M spindle.
RustyFarmall
12-26-2006 14:57:28
If the wide front is an original IH with the tie rods out in front you need to replace the entire assembly with an aftermarket such as a Schwartz, and then you can go heavy duty all the way. If the wide front is an aftermarket, find out what make it is, you might be able to get heavy duty hubs for it.
IaGary
12-26-2006 14:56:44
Yes you can convert them.
If you measure your spindle size and call a good repair shop they should be able to find bearings and hubs that will fit.
Gary
