Tractor Talk Discussion Forum
Ford Tractor TLB
Chuck Frey
12-26-2006 17:34:45
Looking for some help to identify a Ford tractor TLB. On the left side of the trans. boss block (from the seat position)is the numbers 7L03B under this number is C70007. On the right side (above the starter) on the cut away portion of the trans. boss block 8A03B and under it is *C560055* Above the 8A03B over the cut away portion is the letters and #'s KD 211 F. I figured out so far that the tractor was manufactured in Nov of 1977 and completed in Jan 1978. My problem is all models were manufactured in that time period. Everytime I think I have the model there is an indicator that tells me different. For example it's a 3 cylinder diesel. (D5NN6015)The local Ford dealer thought it is a 420, However the fuel return line was pluged and there is no connection on the neck of the fuel tank for the retun line. Could this have been gas and changed to diesel? Any help would greatly be appreciated. confused!!! Loader #'s on the loader frame. On top H7 7700720 on the right side is 201502 and below it is 7705465. I don't know if this will help.
IanC
12-26-2006 20:01:37
 Re: Ford Tractor TLB in reply to Chuck Frey, 12-26-2006 17:34:45
According to the cheat sheet I have dated July of 1992, KD211F codes out to model 445A as follows. K= 445A, D=Industrial, 2= design stage 2, 1= diesel w/ vertical exhaust, 1= no PTO, F= 4x4 power reverser with torque convertor and synchro's. 445A's were made from 1985 to 1988 so date codes are consistant. 445's were 3 cylinder. Your dealers parts person should have been able to find this decoding info on his PAL parts system.
Chuck Frey
12-27-2006 13:30:07
 Re: Ford Tractor TLB in reply to IanC, 12-26-2006 20:01:37
Thank you IanC. Then the 1977 manufacturing date is incorrect?
