Tractor Talk Discussion Forum
IH 450D bearings
Bill46
12-28-2006 05:11:48
Decided to repack the front wheel bearings on the 450D. One fell apart in my hands.
Called CIH and they no longer stock them.
Any ideas where I can find new ones?
Thanks in advance.
D Slater
12-28-2006 10:39:29
 Re: IH 450D bearings in reply to Bill46, 12-28-2006 05:11:48
One dealer has bearing kit 361295R92 listed for $66.50 if you want to compare prices. Thats everything to do one wheel including seal and gasket.
Bill46
12-28-2006 11:23:33
 Re: IH 450D bearings in reply to D Slater, 12-28-2006 10:39:29
Thanks loads D. I will use this.
D Slater
12-28-2006 07:33:25
Dealer not stocking or claiming there not avaliable? They should be able to get them. Two different outer bearings were used on those tractors, there's a serial # break.
Quig
12-28-2006 06:29:48
Bill: on the bearing race and/or cone there's almost always a part number, and any Napa store can cross reference it, either through their computer, or else their master bearing book. On the slight chance they can't cross it, it can be matched by size. Ditto the seal..... I can go in there with a bearing from the 20s and 30s, and most of the time they have me a new one within 24 hours.
Tom N OK
12-28-2006 05:37:25
Hi Bill I have an Allied Bearing Supply close to me that has always been able to supply my needs. So you might check and see if there is a bearing supplier in your area.
Tom
Bill46
12-28-2006 05:39:02
 Re: IH 450D bearings in reply to Tom N OK, 12-28-2006 05:37:25
Thanks Tom.
