Tractor Talk Discussion Forum
OT-Cracked exhaust manifold - repairable?
tractorsam
12-28-2006 15:18:56
While investigating a noise on a new to me car (98 VW Golf (gas)) I found a crack in the exhaust manifold. It looks like someone's made a poor attempt to repair it previously and failed. Any suggestions on what this manifold is made of and how best I could repair it? Many thanks, tractorsam
george md
12-28-2006 21:52:07
 Re: OT-Cracked exhaust manifold - repairable? in reply to tractorsam, 12-28-2006 15:18:56
third party image
Sam,
It is quite repairable if you stay away from anything that has to do with arc weld or epoxy. Epoxy will not stand up to the heat and arc weld contracts so much that it will crack before it is cool, also the thermal cycling will continually add to that problem. You need it on the bench ,a large torch to heat it to a red glow, a smaller torch with
which to weld , some bare cast iron rod , and
a can of cast iron welding flux.
Manifold in the picture and the link was repaired with torch and cast iron rod.
george
Clarkbug
12-28-2006 20:25:20
I would give some JB weld a try first just to see what happens. Its worth a shot, and lots cheaper than a new manifold....
Bus Driver
12-28-2006 15:51:54
I found this video to be impressive.
Stumpalump
12-28-2006 15:41:03
Muffler shops deal with this all day. Find sombody who has been doing them awhile and they will know which ones hold and which ones don't.
tractorsam
12-28-2006 15:20:39
third party image
Whoops, I meant to add the pic that's hopefully now attached. tractorsam
LJL
12-28-2006 15:34:24
 Re: OT-Cracked exhaust manifold - repairable? in reply to tractorsam, 12-28-2006 15:20:39
yes go to your local dealer and purchase a new one
