Tractor Talk Discussion Forum
IH 560
bluesky
12-28-2006 19:57:31
Tractor cranks , but I'm not getting any spark out of a coil w. external resistor. Replaced the coil,resister looks ok (strip and wire loop look intact). Any ideas?
Thanks
Allan in NE
12-29-2006 06:14:11
 Re: IH 560 in reply to bluesky, 12-28-2006 19:57:31
Something wrong on the primary side.
Check your points to be sure they are breaking correctly and have juice. If no voltage there, check the ignition switch.
In the crank position, the resistor is bypassed anyway.
Allan
Stosh
12-29-2006 04:29:44
You might put a jumper wire across the resistor. Then try the starter. If it starts, remove the jumper.
