Tractor Talk Discussion Forum
harvestore dismantle costs
pafreehling
12-30-2006 18:15:12
Does anyone know how much (approx) it costs to have a 16x40 harvestore taken down?
glennster
12-31-2006 08:24:11
 Re: harvestore dismantle costs in reply to pafreehling, 12-30-2006 18:15:12
we had 3 bins moved about 7 years ago. 2 14k bu fs bins and an 8k bu. one 14 was a dryer with stir- rater, as was the 8k. i took the dryers, air floors and concrete blocks out myself, they dropped the bins and moved them. cost about $1500.00 per bin to drop them, $3000.00 per bin to put them back up, included all new bolts and caulkings, concrete was extra. fs did the work.
grazer
12-31-2006 02:34:53
Where are you located.Some times there are people or companies who will take them down if you give it to them or maybe you were going to use it.
Randy as in Randy-IA
12-30-2006 20:27:32
I don't know how much it'll cost but I've lowered the tops of about a half dozen of them to the ground for the crews taking them apart . You can probably expect over a grand to remove one to the foundation . It takes about two hours to rig the cables and remove the remaining bolts to lift them free with the crane at $135 HR not including travel time which is portal to portal . We're cheap on our crane prices too . That has been the upper half of the ones I've done or the top two sections and the lid . I took one apart ring by ring , that one took all afternoon . I heard of a guy that didn't have the money or something and tried to pull one over . No one got hurt but pride and a couple other buildings didn't fare so well or so the story went . Ya can't tell how a circle is going to crush . When the bottom edge folds under it can go anywhere . Hope this helps . ...Randy
Call the local Co-Op and find out from them who's the best in the area for dismantling them .
pafreehling
12-31-2006 14:53:42
 Re: harvestore dismantle costs in reply to Randy as in Randy-IA, 12-30-2006 20:27:32
How much heavier are the jacks for the harv's verses the grain bins. I have maoved many grain bins but never a harvestore which I am looking to buy.
Thanks
paul
12-30-2006 19:09:20
I do not know.
You do know that some companies have a special trailer that will raise up, strap on, & lower such silos, haul them off, & raise them up again on a new foundation? If this is to be sold or set up somewhere else, would be the $$$ way to go.
-->Paul
