Tractor Talk Discussion Forum
Transmission Filling
Cecil Aman
12-31-2006 10:50:59
1949 8N. I am replacing the transmission fluid, and as I have read on numerous times, I removed the bottom bolt on the right hand inspection cover and started filling. I continued filling and watching the bolt hole, nothing happening. I emptied the five gallon bucket, finally decided to check the dipstick and it was way overfull. Could this hole be plugged. I stuck a screwdriver in it until it hit metal, and no trash visible, hole does not seem to be plugged.
Left it set overnight and it drained maybe a pint, but it is still checking over full on the dipstick.
Can someone tell me what is happening, and what I am doing wrong.
Thanks for your response.
Ken L.
12-31-2006 17:28:56
 Re: Transmission Filling in reply to Cecil Aman, 12-31-2006 10:50:59
Why would you use a bolt hole for the oil level when you have a dipstick?
Bob
12-31-2006 21:58:15
 Re: Transmission Filling in reply to Ken L., 12-31-2006 17:28:56
It's common "sage advice" for the "N" tractors to fill only until oil runs out of that hole, which keeps the oil level SLIGHLY lower than the "full" mark on the dipstick, which, if you have ever owned an "N", you will realize is a GOOD thing, as it helps keep the oil from creeping through the poor rear wheel bearing seal setup used on all but the later 8N's, and into the brakes.
Ken L.
12-31-2006 17:28:50
RAB
12-31-2006 16:31:33
Dipstick and level plug? Seems like overkill to me
RAB
a bane
12-31-2006 12:38:34
How did the fluid run out when you drained the old fluid out.
