Tractor Talk Discussion Forum
new holland 553 skidsteer
slowsleeping00
01-02-2007 17:47:09
I was looking to buy a used skidsteer. I found a new holland 553. I really don't know much about this model except it has a kubota diesel. Does any know engine size (hp) lifting capacity, reliability and any other info on this machine.
thank you
Dave from MN
01-03-2007 05:44:11
 Re: new holland 553 skidsteer in reply to slowsleeping00, 01-02-2007 17:47:09
Check the lifting system pivot points for slop. Look at the quick attach system for breaks, both common issues. When the lift system gets real sloppy they seem to have a problem with the lift knocking off the fuel cap, easy fix is to weld or bolt on a slide next to the fuel fill area to keep arms from hitting cap. I use one quite a bit for a freind loading manure. Has nice lifting hieght, quick hydraulics, and is adecent machine. It does like the fuel compared to a 753 melroe bobcat from my experience.
jhill52
01-02-2007 18:03:42
About 50 hp and 1500 lb lift capacity.
