Tractor Talk Discussion Forum
Re: Factory Prototype Questions ....
Dean Barker
01-04-2007 08:11:40
There is not whole lot of difference between my experimental 120 and the production models. The cab has a red interior, it has 3 7/8 dia axles, the O/U has electric controls like the American 60 and 80, and the engine side panels are slightly different. We made a slight change in the transmission input shaft, so my input shaft is different and the final drive housing is different. I do have a spare input shaft, but I don't think the first one will ever wear out. It also has the White 100 transmission gears. That is about all I can think of at this time about what is different. I plan on using this tractor until I retire from farming. It currently has around 1600 hours on it. The engine oil is changed at least every 100 hours with Mobil 1300 15W-40. I put 18.4-42 Firestone tires with step up rims a couple of years ago. It is equipped with 5 sets of rear weights and a full rack of front weights. I mainly use it for fall tillage, so I keep it weighted to about 17,000 lbs. I also use it for blowing snow. Your 145 is a nice tractor also.
Dean Barker
01-04-2007 08:32:59
 Re: Factory Prototype Questions .... in reply to Dean Barker, 01-04-2007 08:11:40
I see I didn't answer all of your questions, j meyer. This tractor was built in Charles City, Iowa at the Oliver plant. It was built by the guys in experimental. It was started in early 1985 with the transaxle being built. We were laid off in March of 1985 until Jan 1986. As it had the wrong transmission, another 120 was built with the right transmission and sent to our Phoenix test facility for testing. My 120 was then completed and used for a lab tractor which is why it had so few hours. A guy that did custom corn shelling with a JD sheller used it for awhile, one of the other engineers used it on his farm for some time, and then it came back to the plant and used in experimental. It was put up for sale, and I bought it. Over a year later, we found out that Cummings still owned the engines in both my 120 and the 140 that was sold. I never did find out how that was settled, but I assume that White had to pay for them. These two B series engines were some of the first that Cummings had assembled. Mine used a quart of oil every 10 to 70 hours, depending what weight of oil I used, until it had about 1200 hours. Then it quit using oil; I'm assuming that it finally got broke in. It seems to be easy on fuel; it will do the same work as my John Deere 4320 on about 2 gallons less an hour.
