Tractor Talk Discussion Forum
830 CASE
Steve Masterman
01-06-2007 16:25:30
hey guys can i tow my 830 caseomatic to start it?
RAiken
01-07-2007 09:40:30
 Re: 830 CASE in reply to Steve Masterman, 01-06-2007 16:25:30
Yes it can be done. I have pull and coast start my 830CM several times. If you have enough battery and a good starter, put in gear, set throtel, pull decompresion leaver, pull direct drive leaver, wind up engine until hydrolic pressure holds direct drive in, and you are on your way. Something I made that works good is a 3 to 1 reverse gearbox on the PTO of one tractor to start an 830CM through the PTO. This way you don't need a helper.
Dale In Tx.
01-06-2007 16:38:18
NO
Steve Masterman
01-06-2007 17:01:03
 Re: 830 CASE in reply to Dale In Tx., 01-06-2007 16:38:18
thanks
