Tractor Talk Discussion Forum
stuck motor
Mike Cummings
01-07-2007 13:37:35
Hi folks just bought a 1938 Farmall F-20 with a stuck motor.Had sat inside for 9 years.Took head off and oil pan.Loaded cylinders with B-Blaster and even put a little heat on cylinder walls.Still can not break loose.Any other ideas?Thanks much
Mike Cummings
01-07-2007 17:35:44
 Re: stuck motor in reply to Mike Cummings, 01-07-2007 13:37:35
Hey guys just did the diesel fire thing.It did come loose.THANKS SO MUCH
Maark
01-07-2007 15:35:34
Take the cover off the knuckles between the clutch and tranny. get yourself a long bar,while standing on the right side, insert it in the knuckle assy and pull down jarring it as you put down pressure on it. You may want to install the head to keep the sleeves from coming out.
old
01-07-2007 15:31:59
PB works ok on bolts but not well on pistons/rings. Take a rag and soak up the PB and then fill the cylinders with tranny fluid. Let it sit for a few days or a week. Watch it close and top it off if you find any cylinders getting low, that tells you its working. If after a week it hasn't popped loose then take a tablespoon of gas and pour it in on top of the tranny fluid and light it up. Let it burn till it goes out. If those 2 things don't work then its time for the hammer and bloke of wood and maybe new pistons. Doing those things has worked for me on more then 10 engines in the last 2 years and only one didn't pop free and even it did on all but one cylinder and it needed a new sleeve
RustyFarmall
01-07-2007 14:43:15
Not to be the bearer of bad news or anything, but sometimes the only way to get those pistons out is to destroy them. If yours has been stored in-doors, it is probably not that bad.
Don L C
01-07-2007 17:28:20
 Re: stuck motor in reply to RustyFarmall, 01-07-2007 14:43:15
Be careful, those F-20 engine parts are getting hard to find..... ...tranny fluid will do it just takeyour time.....
Delta Bob
01-07-2007 14:38:13
Try putting the tractor in high gear and gently rocking the rear tires forward and back, if this does not break it loose, you will probably have to remove the rod caps and tap each piston down with a block of wood and a hammer.Note that this sometimes damages the ring grooves of the stuck pistons.
Pete in Cal
01-07-2007 14:17:09
Posted previously by Brian (?): pour a small amount of diesel in each bore and light it on fire. The heat will expand the parts and free it up. Easy to do since you already have the tin and head off.
