Tractor Talk Discussion Forum
A FARMALL
HN
01-08-2007 08:27:42
What makes and A burn voltage regulator & points
up.
Thanks Buddy
Bob
01-08-2007 12:23:06
 Re: A FARMALL in reply to HN, 01-08-2007 08:27:42
If you mean it is burning up voltage regulators AND distributor ignition points, there may be a short in the generator's field circuit, making it overcharge, out of the control of the voltage regulator.
Check the charging voltage at the battery (with an ANALOG meter). It should not exceed 7.4 Volts.
Or, do you mean it is burning up the points in the VOLTAGE regulator?
Also, is the system still correct, as-OEM, (+) ground?
daniel naeger
01-08-2007 08:39:55
Vibration--is volt. reg. mounted on rubber.
