Tractor Talk Discussion Forum
Vicker Vane pump
NCCub
01-08-2007 18:40:00
Anybody know a shop who has dealt with these pumps a long time? I need a seal for mine that runs the front end loader on a MF 35. No id tag on mine so no one can help. Hoping to find someone with experience, I need a seal with 31/32 inside diameter.
Kerry
Doug in IL
01-08-2007 19:19:45
 Re: Vicker Vane pump in reply to NCCub, 01-08-2007 18:40:00
I just did a Yahoo search for Vickers Pumps. Many sites came up. The one I clicked on had parts diagrams for a bunch of pumps. You probably have a 10 or 20 series single rotor fixed displacement pump. Vickers uses a common pump "size" for different gallon per minute models. The difference being the thickness of the center section. If you take the pump apart be sure to note on which side the bevel is on each vane. As I recall, I think that 31/32 size is a real common one. Those pumps have not changed a lot down through the years. Hope this helps some.
NCCub
01-08-2007 19:55:34
 Re: Vicker Vane pump in reply to Doug in IL, 01-08-2007 19:19:45
Thanks for the reply, I will check it out.
Bob/Ont
01-09-2007 05:15:54
 Re: Vicker Vane pump in reply to NCCub, 01-08-2007 19:55:34
Keep all parts of the cartridge together. Vanes, rotor and camring. These pumps can be set up to run either direction. one part in wrong and they will not pump.
Later Bob
