Tractor Talk Discussion Forum
O/T: Trailer Question
alg
01-10-2007 13:39:14
Fellow by me is selling a frame from a travel trailer/camper.I'ts about 22'long and good and wide.Want to make it into a tractor hauler.He's not quite sure of the rating's of the axle's,it's a double axle w/brakes.Anyone have an idea want the axle's might be rated for.?
Richard H.
01-10-2007 20:50:53
 Re: O/T: Trailer Question in reply to alg, 01-10-2007 13:39:14
Well that is how I did mine, and after reading all the replies below and no one confessed to doing one on there own, here goes. The axles are tagged and mine are tagged at 5500# each. About a $1000 dollars in steel including dove tail and tilt ramps, about $300 for treated lumber, I forget how much the 350, 3" tek screws cost. The reflective tape and lights prolly about $150 and a lot of time.
I"m pretty good at structural stuff and it is a very sound deck over. But I would find a good used one before I would do that again.
Richard
IBorange in TX
01-10-2007 19:27:26
I agree with the others, BAD IDEA, BAD IDEA. That trailer will make a good lawnmower trailer, but not a tractor trailer. I'm thinking now, tractor being of the IH model H or M, or JD A,B, H or G. Go out and buy you a car hauler for the tractor or even buy the steel and build you a car hauler. It may seem like a lot money up front, but it will save the white knuckles and the hip pocket. Don't use a RV trailer frame for that type of trailer. Just not good judgement..
Good Luck.....
Mike Van
01-10-2007 17:43:13
Those axles should have an aluminum tag wrapped around them giving the info/weight that their good for. I'd guess 3500 lb ea, total of 7000 lb trailer & load. The frame itself on a camper is too light, the guage of the steel to thin to be hauling tractors. You can save the axles, brakes & springs. and make a 7000 lb GW trailer, which is a good landscape trailer.
Don LC
01-10-2007 16:16:28
No...! The frame is to light to be hauling a ractor..... As a RV the weight is spred out over every inch of the frame....a ractor will bend the frame..... .dont do it,,,,,Don
Stumpalump
01-10-2007 15:30:46
I went thru 3 trailers before I bought a real car hualing trailer. I don't miss those days white knuckling it down the road one bit. If it's dirt cheap build up a nice trailer and sell it and get a real one. A bad trailer will give you chest pains or worse.
IaGary
01-10-2007 14:59:21
The only reason it has two axles is to ride smoother.
I would be surprised if they are rated much over 3500 like Caterpillar said.
And frame is probably even lighter because half of the strength in the trailer is designed into the side walls.
Might work good cut down for a lawn mower trailer.
Gary
Aaron SEIA
01-10-2007 14:32:44
What is the weight of the tractor you want to haul? You could easly cut the frame down to about 16' which will more than haul one tractor. Leave the axles a bit back and let your truck take some weight. Should be a build tag somewhere with the weight rating of the axles. 22' might be twin 5k or twin 3.5k axles. I'd think it would haul something smaller.
Aaron SEIA
CaterpillarAl
01-10-2007 14:26:06
A 22' travel trailer is probably only about 3,500-4,000 pounds and it is spread out over the whole frame. I agree, sounds like a bad and possibly dangerous idea.
RustyFarmall
01-10-2007 13:49:58
Bad idea. The frame and axles can't possibly be rated strong enough to make a trailer that will haul your tractor.
BarryfromIA
01-10-2007 18:05:30
 Re: O/T: Trailer Question in reply to RustyFarmall, 01-10-2007 13:49:58
Hi folks. If you stay some under the tow and combined weight ratings of your tow vehicle and trailer, things go much better and no chest pains. You will have to find something else to do for excitement.
alg
01-10-2007 19:42:04
 Re: O/T: Trailer Question in reply to BarryfromIA, 01-10-2007 18:05:30
Guys, thanks for the reply's.You talked me out of it.I'll keep looking.
