Tractor Talk Discussion Forum
OK it boils down to two tractors
Raleigh
01-11-2007 16:02:24
Here is the scoop. It all boils down to two machines. One is 1500 miles away, its a 1968 JD 4020 that cost the cost is 5800.00 the cosmetics are not great by a long shot, the sales man just simply says it runs and shifts out good. This about all he said. I have about 8 pictures of it. It has diff locking and two remotes. It looks by the hour meter that it has a fresh overhaul or a fresh inframe on it. The tractor is at a dealer. The cost to go up there is about $350.00 and to ship this machine is $1300.00 which comes to a grand total of $7450.00...
Like I said the cosmetics aren't great, it has 2 remotes, it has 830 hours on some sort of inframe or overhaul, and the guy says it sifts out and runs good.
The second machine is Much Much closer than the first it is here in state and an easy drive to go see. It is prety straight and clean by the photos could use a paint job. It is a late model 1971 JD 4020 only one remote has diff locking. I can go down and have it pulled on a dyno I can drive it, I can do what I need to do to check it out. The price is $8,000.00 and to ship it it is less than $300.00. So a potential $8300.00 total investment.
I have to say it is a long shot that I will go up to North Dakota, even if the cost is only $350.00 to see this tractor. I will really have to buy it with out trying it out. So it boils down to a 1968 tractor for 7100.00 cause I want be trying it out, or $8300.00 for a tractor I can spen Quality time with before I make my purchase.
Question which way or how would any of you give advice on this? What are yalls opinions?
Any comments are greatly welcomed..
Raleigh
01-12-2007 07:29:09
 Re: OK it boils down to two tractors in reply to Raleigh, 01-11-2007 16:02:24
Well Guys I am headed to the bank right now and then I will be headed over to the dealership to see what I have been anticipating for at least TWO YEARS!!!!! !!!!! !
I strongly apprciate the ton of effert each of you have put into this in helping me through the years.....so we will see what happens!!!!
TomTX
01-11-2007 20:02:24
What do you mean with "it has 830 hours on some sort of inframe or overhaul"? Any dealer who wasn't trying to cheat you to death, would be glad to show the list of parts that were put into it. Beware when people say "overhaul", they may mean repaired by the cheapest means available. I would LOOK at the closer tractor, then keep looking awhile. There was lots made and many for sale. Tom
Doug in IL
01-11-2007 19:03:37
Raleigh I"ve been following your quest now for a while. Real estate is always said to be location, location, location. Used tractors are condition, condition, condition. Don"t get hung up on the model year thing. I have, and have had, them all, including the 4320. Other than the dash mounted hydraulic controls, there is not enough difference in them to amount to anything. And for some uses, I actually like the dash mounted controls better. Like operating a bale wagon. Remember, the earlier tractors are the ones that built the 4020"s reputation, there"s nothing wrong with them. Condition is what you need to worry about. Decide which transmission you want. Then, start looking for the best one you can find, forget what year. You need to look at these tractors in person. You need to drive them. Where is the best place to find them? Well, I suppose you could find one anywhere. In my opinion, look in the row crop cash grain areas. Upper half of Illiniois and Indiana. Southern Mn. Upper 1/3 of Mo. Try to stay away from heavy livestock areas, lots of loader use. Stay away from Southern tractors, usually tons of hours and not well shedded. Great Plains tractors can be ok, but they are usually not shedded either. Try to find as low houred tractor as you can. Yes, engines and transmissions can be rebuilt. But high hours also take the toll on everything else. Steering, hydraulics, brakes, final drives, axle bearings, cooling systems etc. You need to know how to evaluate a used tractor. Or find someone who does to accompany you. For example, do you know that you can glance at one of these syncro tractors and pretty much know how much clutch life is left? Shift linkage wear, pedal wear, steering wear, brakeing action, hydraulic response, pulley wear, hitch wear, all of these things and more can help you verify a low houred tractor. There are a lot of 4020"s out there. But, try to look at them in person!
Mike M
01-11-2007 18:40:37
I would never buy without seeing in person.
A late model 4020 side console model for $8,300 I can't say I have ever heard of them selling that cheap here in Ohio. I'm sure they have some room to budge on the price. Go check it out pick it apart and make them an offer. Most dealers have some kinda warranty I'd think.
Allan In NE
01-11-2007 17:54:42
Gee Whiz Raleigh,
There's one on page two of the photo ads with a loader located in Iowa.
Guy is only asking $16.5K for it, so if you figure in the "Green Paint Currency Exchange Rate", that makes it worth about $6K of real actual value.
Gotta watch these things. :>)
Allan
Bob
01-11-2007 19:18:12
 Re: OK it boils down to two tractors in reply to Allan In NE, 01-11-2007 17:54:42
;-) Hey Allen, ;-)
Well, at least it won't new a new TA! That makes it a little more affordable!
Raleigh
01-11-2007 18:58:55
LOL!!
tom43
01-11-2007 17:32:28
Dear Raleigh,
Forget the tractor that is far away. The 1971 and 1972 4020s are far superior to the older models. The console models are 12 volt with a reliable alternator and are much more convenient to use. Even though 69 and 70 4020s are console models they have discontinued style injection pumps. Also don' limit your search to one tractor. Take your time and look at several.
msb
01-11-2007 18:33:54
 Re: OK it boils down to two tractors in reply to tom43, 01-11-2007 17:32:28
I am with Tom on this especially if the tractor has the larger JDB injection npump on it.The 210,000 and up serial numbered tractor is a much improved model over the 64-68 models even if I don't like the knee knocking side console.
Raleigh
01-11-2007 17:44:56
Thanks a bunch.....
Randy as in Randy-IA
01-11-2007 17:18:43
Hi , If you are close to Waverly Iowa theres a real nice 4020D syncroshift with a 1300 cab for sale at Hilpipres auction yard . The tractor looks REAL good . I thought it was a new tractor until I got within about 15 feet of it . It has front weight bracket with weights , a TPH , front fenders and good tires . I wasn't interested in it so didn't look any closer . It did have telltale signs of use but the general look of it was good and it ran good to since the auction employee was backing it out of the garage . From what I did pay attention to I wouldn't be afraid to put it in a parade . I don't know what they are asking for it or if it's waiting for an auction . The # there is 319-235-6007 ask for Merv Hilpipre . He's not there often so you might have to keep trying . Be forwarned that he's NOT an easy man to talk to but your results may vary . ...Randy
Gerald J.
01-11-2007 17:17:26
Now you are beginning to compare apples and oranges. There is a great deal of difference between the '67 and the '71 4020. Especially the hydraulics but also the engine.
Factory remotes are easier to add to the later 4020 than the earlier one, but on either its not difficult or expensive to add as many remotes as you can ever wish, so long as you can find room for them. You simply plumb in valves just like you plumb in the loader with its own valve.
There ought to be at last another 500 4020 in between your place and ND that are for sale and could be considered.
Gerald J.
Raleigh
01-11-2007 17:29:48
 Re: OK it boils down to two tractors in reply to Gerald J., 01-11-2007 17:17:26
Well what are the major differeances between a late model and an early model? I know of a wheel and deal type guy down here who buys and sells these things who wants $500.00 more for the late mode 4020 as apposed to the early model.
Well as far as trying to find one localy it really is tough. There have been several factors involving as to what the reasons were. Some were power shift, most did not have diff locking, Most could NOT be Dynoed and were sold from an individual.
You are soo right though I sould be able to find one in my back yard here locally. I guess if I look long enough I can find one. But Hey, this one for $8,000.00 is local...
Gerald J.
01-11-2007 20:37:03
 Re: OK it boils down to two tractors in reply to Raleigh, 01-11-2007 17:29:48
Well to start the hydraulics are different. The side console 4020 has the remotes and remote valves down on the back of the transmission, the same design was used for decades after 1969, if not still.
The side console engines don't have a crankcase ventilation pump.
There's the side console.
The side console tractor has a deeper dish to the steeering wheel.
The side console, as you know, has an oval muffler for a bit better forward vision.
Most early 4020 diesels were built 24 volts unless shipped with an airconditioned cab. Then they were shipped 12 volts. I've seen it said all side console diesels were 12 volt. I don't know that is true or false. Converting from 24 to 12 isn't hard, Deere sells a kit for the task, about $600 the last time I saw it advertised. The big expense would be the Nippondenso starter as I see it.
In Iowa a side console 4020 starts out at least $4000 higher than an earlier tractor. And there are those lusting after the last year who will pay as much as a working 4230 with a good cab goes for, up about $14.5K.
There are enough differences that all the shop manuals and parts books are separate, even the I&T manual treats them separately. Some of the fundamental hydraulic tests good for the early tractor damage the test equipment (and the operator) if tried on the side console tractor.
Somewhere along the line engine sizes were larger in the side console than the early though it may have only been the gas engine that was different.
You can probably find more differences if you compare the owner's, shop, parts, and I&T manuals. While you are looking you should own at least one of these. The I&T is the most general and least informative but the least expensive since there are at least three editions of the owner's manual and two of the parts and shop manuals. And the parts manual may not describe enough about the parts other than Deere part number to identify the differences, though when parts are the same from early to late, the part numbers probably will be identical.
Since I own an early gas tractor, my books are biased to it and I don't have the later books and I'm no authority on diesel injectors or injection pumps, though I do see in some parts catalogs that there are at least a couple different sizes and models of injectors that were used, clearly not interchangeable.
Gerald J.
Tx Jim
01-12-2007 04:49:24
 Factory 12v 4020 diesel? in reply to Gerald J., 01-11-2007 20:37:03
Gerald J,if JD shipped a 4020D cab/ac tractor/12 volts which I don't remember,why doesn't JD parts book show a listing for a 12 volt diesel starter on said tractor? Thanks,Tx Jim
Gerald J.
01-12-2007 09:07:40
 Re: Factory 12v 4020 diesel? in reply to Tx Jim, 01-12-2007 04:49:24
I thought it (for SN before 203,000) but you are correct. The alternator option there is a 24 volt alternator.
Last night I looked in the I&T manual and it had nothing on 24 volt diesels in the section on the side console tractor, just 12 volt starters and alternators.
I'm sure the many older 4020 that have been converted to 12 volts adds confusion.
If I had a 24 volt 4020, I don't know I'd spend the money to convert to 12, though since I don't run the tractor all day every time I start it, I'd want an alternator to charge those batteries in ten minutes instead the 6 to 8 hours that 10 Amp generator had to have taken. And if I couldn't make an alternator with a ground so it charged the batteries independently (and I think that would only take one added wire from the alternator insides), I'd seriously consider two independent alternators to do that. The small generator and the demand on keeping loads balanced to balance the battery chargeing were the achille's tendons of the 24 volt system. And those weaknesses lead to failures that confused many users and shops.
But then I'm an electrical engineer who knew what the insides of a motor winding looking like before I learned the math of them in school.
Gerald J.
Tx Jim
01-12-2007 13:51:32
 starting SN for 4020/console in reply to Gerald J., 01-12-2007 09:07:40
Gerald J,Serial # 201,000 was the first 4020 diesel that could have come from factory as a 12 volt system not 203,000. Tx Jim
Peabo
01-11-2007 19:00:11
Sometimes buying from an individual can be a good thing. Sometimes a dealer will cheat your eyeballs out!!!! Not all, but some!! $8000 sounds about right for a decent 4020 around SC. Not a steel but not overpriced from what I have seen in local classifieds. GA is only one state away. Have a good one
-Peabo
Mike in Ind.
01-11-2007 17:03:59
I agree with Brian, I never hurts to shop around and a good 4020 is plentiful in most places. If your set on one or the other I would certainly take the closer one. I never buy any thing that I can"t run and drive.
two mile
01-11-2007 17:03:01
Amen
Brian in MO
01-11-2007 16:52:22
Don't think there's any decission to make. I wouldn't even consider a tractor that far away when there are so many of that model, there has to be some closer than 1500 miles. It would be different if it was something rare.
Raleigh
01-11-2007 17:18:14
 Re: OK it boils down to two tractors in reply to Brian in MO, 01-11-2007 16:52:22
Well...what about the price differance? The one 1500 miles away cost 7450.00 while the one local cost 8300.00...but for 7450.00 that only includes the cost to go see it, not he hassel involved to go see it.
Clarkbug
01-12-2007 03:33:04
 Re: OK it boils down to two tractors in reply to Raleigh, 01-11-2007 17:18:14
You are right, the one that is 1500 miles away is cheaper, but you dont get a chance to spend any quality time with that one. For all you know its gong to need some 750 tranmission parts once you get it home because you couldnt drive it to hear the gear whine...
Plus, if you do travel up there, look at it, and then decide not to buy it, now you are out another 500 and will probably go look at the local one anyway.
Go see the one near your house, run it well, and see if it does what you want it to do and has what you are looking for. If it does, buy it. If not, figure out what its missing that you really want, and then just find one that has all of those things.
