Tractor Talk Discussion Forum
help needed re-garding loader
craig garloff
01-12-2007 04:45:00
I have a 1700 ford with a 770 loader and I am renovating it. I put the laoder together and when I lower the loader it pulls the engine down. When tractor is off the loader will go down with ease. The loader goes up without pulling the engine down. What could be wrong?
massey333
01-12-2007 06:34:49
 Re: help needed re-garding loader in reply to craig garloff, 01-12-2007 04:45:00
Soundes to me like you somehow have a two way valve feeding a one way cyl.with no where for the oil to go other than thru the relief valve.If the valve can't be switched to one way operation then you need to put a return hose from the downside of the valve back to the sump giving the oil somewhere to go.
john cub owner
01-12-2007 06:21:33
Does it possibly have a retarder valve to prevent sudden drops, such as form a burst hose?
IaGary
01-12-2007 05:07:48
third party image
My 1900 does this also but not real bad.
Never have figgered that bugger out.
But it is worse if you pull back to far on the 3 pt lever and cause it to by pass.
I'll be interested in any solution also.
Allan you got mail.
Gary
Allan In NE
01-12-2007 04:52:53
Craig,
Did you put a new control valve on it? Does it pull the engine down a lot or just "some"?
Allan
