Tractor Talk Discussion Forum
Filling tires with fluid ?
Lou
01-12-2007 12:42:47
Im planing on using window washer solution to fill a 14.9x 24 tire. How many gallons will I need? thanks
CaterpillarAl
01-12-2007 14:36:39
 Re: Filling tires with fluid ? in reply to Lou, 01-12-2007 12:42:47
I didn't know you could use windshield washer fluid? Some guys use beat juice around here. Is there a widget you can buy that attaches to the valve stem to get the fluid in?
Lou
01-13-2007 07:51:41
 Re: Filling tires with fluid ? in reply to CaterpillarAl, 01-12-2007 14:36:39
Try Gemplers 1 800 332 6744 . product # AQF 1
Greg_Ky
01-12-2007 13:01:54
My chart says 47gal. @ 75%.
old
01-12-2007 12:57:56
The chart I have in my Ford 801 series tractor owners manual says 53 gallions for a 14-24 tire. So that should put you right in the ball park
Lou
01-12-2007 13:06:24
 Re: Filling tires with fluid ? in reply to old, 01-12-2007 12:57:56
Wow I better start shopping for a better price, thats more than I thought .
buickanddeere
01-12-2007 16:20:53
 Re: Filling tires with fluid ? in reply to Lou, 01-12-2007 13:06:24
The washer fluid is good for -40F. Odds are you will never see 0F. The fluid could be diluted at least 50/50.
old
01-12-2007 13:36:30
Me also. I know the 12X28 holds less as per that charts so it surprised me that the 14X24 woulkd hold more. The chart has the 12-28 holding 38 gals. and the 13-24 holding 44 gals so I think it has to be a miss print in the chart. I'd probably go with maybe 30 or so gals
