Tractor Talk Discussion Forum
diesel engine exhaust
in sticks
01-12-2007 13:26:43
friend has a little jd diesel tractor.mine is bolens.about same h.p.about same age.exact same fuel.his tractor exhaust will burn your eyes and stinks more.mine not so bad.told him it's the way fuel is injected and burns.any ideas?
Mike M
01-12-2007 17:49:01
 Re: diesel engine exhaust in reply to in sticks, 01-12-2007 13:26:43
Those JD compacts use Yanmar engine and is recommended to adjust the valves and test the injectors every 500 hours. How many hours do you have on it ? Those injectors also wear the tips out sooner than some others. And by all means put in a new air filter and fuel filter.
buickanddeere
01-12-2007 16:16:28
Has your buddy ever replaced the air filter? Those little Yanmars are noted for being good engines. Is he burning some 2-3 year old high sulphur fuel? Try some ultra low sulphur highway fuel. Does he drive around with the engine at idle speed or reved up?
Bob
01-12-2007 14:28:14
Does he have a functioning thermostat, so the engine gets properly warmed up?
Also, if the injection timing is a little "off", or an injection nozzle or two is dirty, or not holding the correct "popoff pressure", the exhaust will be "dirty".
big hunter
01-12-2007 13:49:48
maybe keep your face farther away from the exhaust pipe...lol
big hunter
01-12-2007 13:49:45
