Tractor Talk Discussion Forum
Bottom PTO on 4020
Raleigh
01-13-2007 12:55:03
Hey I have always noticed the bottom PTO on all 4020's What was this used for?
I hate to sound dumb here but was there ever a Belly Mower thst used this?
Was there even a Belly mower made for the 4020? Who makes it?
DETROIT DEERE
01-14-2007 16:26:53
 Re: Bottom PTO on 4020 in reply to Raleigh, 01-13-2007 12:55:03
BILL:
THE PTO IS FOR A # 50 SIDE MOUNTED MOWER. i HAD ONE ON A 3020 & 4020 ONE TIME. JOHN
Bill Pittnone
01-14-2007 10:32:35
When you put a loader on these tractors mount the pump on this shaft and leave it on. This leaves the rear shaft open for other uses.
buickanddeere
01-14-2007 10:41:21
 Re: Bottom PTO on 4020 in reply to Bill Pittnone, 01-14-2007 10:32:35
A new Generation Deere doesn't need an auxilary hydraulic pump tinkered on in order to run a load. Other brands, sure. Deere is noted for hydraulic flow, pressure and reliability.
Glen in TX
01-14-2007 08:12:43
 JD No. 50 Side Mount Mower in reply to Raleigh, 01-13-2007 12:55:03
third party image
JD No. 50 side mount sickle mower drives off front mid shaft PTO on JD 2510,3010,3020,4010,4020 row crop and standard tractors and maybe some later JDs also. Also with a different frame mount bracket & drive pulley fits JD 1020 & 2020 utility tractors. Made 1960s ? 1966 till ?? Crankshaft speed 900 RPM drives off 1000 RPM PTO. A different deeper frame mounting bracket and longer pulley with spacer is used for the taller row crop tractors than with the utility tractors. Belt drive with a double groove pulley with split center mounted on mid front PTO shaft. Covered in Operator Manual OMH62804 for mower serial numbers before (****-3000), Operators manual OME41162 serial#s (3001- ), Part Catalog PC1012.
Glen in TX
01-13-2007 22:26:24
Several had that shaft underneath facing front. Our 2510 had it too and a few of the JD utility tractors also had it. There was a JD mid mount sickle mower that ran off it but I can't remember the model number right off hand. Remind me later and I'll look the number up for you. Maybe some cotton pickers or strippers also drove off it too?
Tx Jim
01-14-2007 03:29:08
 #10 sickle mower in reply to Glen in TX, 01-13-2007 22:26:24
Glen,I think the model # was 10 for side-mount sickle mower. Tx Jim
Glen in TX
01-14-2007 07:09:58
 Re: #10 sickle mower in reply to Tx Jim, 01-14-2007 03:29:08
Jim, It was No. 50 JD side mount sickle mower. A pic & more info in a bit if I'm not in the dark from the ice. My notes say the No. 10 JD was a side mount for the 2 cylinder 30 series tractors ? But I have no manuals or pics of the 10.
big jt
01-13-2007 15:58:28
The 3020's had them also.
there was also a snowblower that used this shaft also.
jt
Gerald J.
01-13-2007 13:27:30
On the 4010 the front PTO shaft shifted speed with the rear shaft. On the 4020 the front shaft is always 1000 rpm.
Gerald J.
SMinWi
01-13-2007 13:04:45
It's call front or mid PTO. John Deere made a side mounted mower that run off of the PTO. Yes they made one for the 4020.
Raleigh
01-13-2007 19:27:27
 Re: Bottom PTO on 4020 in reply to SMinWi, 01-13-2007 13:04:45
So does anyone know of a good belly mower that would fit on a 4020?
JMS/MN
01-13-2007 18:48:01
Used mine on the 3020 to run the sprayer pump- left it on the tractor, just pulled the belt off the rest of the year when pto was used for other jobs. Had saddle tanks on the tractor- sprayed herbicide with the planter or later in the year. Good idea that JD had. Too bad they dropped it with later series tractors.
