Tractor Talk Discussion Forum
Periodic Popping noise in breather
Oddbob
01-13-2007 17:48:59
I have a 1949 farmall C, I had the fuel tank boiled and lined, I put a new sediment bowl on, new manifold, new zenith carb, new plugs,wires and cap. The engine runs fine at idle with a periodic miss, give it a little fuel and the miss is worse along with a pop noise in the breather. I looked at the valve springs for possibly broken one. All looks well. the pop and miss is not continous. thanks
Jim Johnson
01-14-2007 05:52:47
 Re: Periodic Popping noise in breather in reply to Oddbob, 01-13-2007 17:48:59
If it pops back under a load or when you yank the throttle it could be a lobe dawn on the cam. Jim
las vegas
01-13-2007 18:56:58
burnt/improperly seated intake valve. More than likely than not.
Olivergreen
01-13-2007 18:21:29
Well I'm gonna open a can of worms here. That old 77 would work great if you run it every day. If it sat one day that valve would stick & bend the push rod. I added Auto tranny fluid to oil & fuel. But my old uncle tried this on his f-20 & told me. Get it ta operating temp & pour stp on the hot valves & work it in. After I did it on that old gal no more trouble.
Olivergreen
01-13-2007 17:54:48
Sounds like a sticking intake valve. Maybe adjusted to tight Or just gummed up.
Olivergreen
01-13-2007 17:58:38
 Re: Periodic Popping noise in breather in reply to Olivergreen, 01-13-2007 17:54:48
Hey Bob, Thought of one more. Bent push rod.Had a 77 do it to me. Valve would stick & bend push rod.
Oddbob
01-13-2007 18:11:12
 Re: Periodic Popping noise in breather in reply to Olivergreen, 01-13-2007 17:58:38
is there a cleaner for this or do I need to have the heads worked? thanks
