Tractor Talk Discussion Forum
E-350 MAHINDRA tractor SLOW OIL FILL Solution
Larry D.
01-14-2007 09:31:17
On My 2003' Mahindra E-350DI it is a real problem with the Oil BUBBLING Back and taking a Looong Time to pour the fresh Oil in, So.... I have Solved that problem,<> <> just get a Drinking Straw and slip down inside the Filler NECK to let Air be Dispersed and problem Solved, Oil will pour in easily..OLE! No Bubbling Larry
edwkin
01-14-2007 10:39:29
 Re: E-350 MAHINDRA tractor SLOW OIL FILL Solution in reply to Larry D., 01-14-2007 09:31:17
Is the sump breather vent blocked.
Larry D.
01-14-2007 10:43:55
 Re: E-350 MAHINDRA tractor SLOW OIL FILL Solution in reply to edwkin, 01-14-2007 10:39:29
No.. On the Breather, theres nothing out of place/wrong, it's just they way it's made...Theres not much of an opening between the filler and the top of the Valve assembly it just needs some air to displace the Oil being poured in.. Larry
Bob
01-14-2007 10:17:32
I have no experience with a Mahindra, but on certain other engines, simply pulling the dipstick will accomplish the same thing... let the air out as the oil goes in.
Mike M
01-14-2007 11:58:49
 Re: E-350 MAHINDRA tractor SLOW OIL FILL Solution in reply to Bob, 01-14-2007 10:17:32
That's the trick I have to use on my JD's LA and M
Larry D.
01-14-2007 10:46:15
This may work as well, Never thought of that..
