Tractor Talk Discussion Forum
HELP!!!! 986 trouble
TMay
01-15-2007 04:24:50
Well i bought a IH 986 the other day. There were no leaks around it what soever. We have drove it up and down the road and nothing. So yesterday I change the oil and filters. Take it for about a 3 mile run down the road. Go over a big hill climb back up to check the clutch. Get back to barn and all of a sudden oil coming from under tractor. Pretty good puddle. Guessing the rear main seal. Thats my luck LOL. Was wanting to know how hard is it to fix. Do I have to break it in half. I have never had a IH so I don't know much about them. Also The remotes on it. I tried to connect my roll baler to it yesterday and found out I can't because the remotes are to big for the hose ends. Was wondering do I need to change the implement connections or is there an adaptor? Like I said not had IH before. All of your help is appreciated. Tim
fixerupper
01-15-2007 11:06:56
 Re: HELP!!!! 986 trouble in reply to TMay, 01-15-2007 04:24:50
If it's the rear seal, it will have to be split, but that's not too tough of a job. Working on the steering motor isn't too tough either. IH used to have a change over kit for the hyd couplers so you can plug 'pioneer' type fittings into them but I don't know if they are available anymore. They work pretty well, you just push the hoses in to plug them in and give them a good jerk to get them back out. Whether or not you want to convert just depends on how often you plug hoses into it. Jim
IaGary
01-15-2007 04:56:26
TMay
If you decide to change the ends on your hoses give me a shout.
I have several of them left over from when I switched back to pioneer.
I got around 50 IH ends here.
Gary
IaGary
01-15-2007 04:35:44
Yes there are adapters you can just plug in.
On that oil leak.
Look up higher and make sure its not coming from the steering motor.
Gary
