Tractor Talk Discussion Forum
new barn almost finished-photo
Tim, Ohio
01-15-2007 12:03:32
third party image
Hey guys,
Here is our 30 x 56' barn. Thought I would share a photo of it. I started planning this last September asking all of you questions about bracing. I built this barn on concrete pilings. Each pole had a concrete piling to stand on at grade. The concrete was poured to the frost line after drilling 18" diameter holes. A post anchor was fastened to the top of the concrete with a 4.5" lag bolt. Each pole was fasted to an anchor, then stood up with bracing. We used a laser to give pole dimensions so we could cut them before standing them up. Everything was right on. I didn't like walking on the roof much. That 4/12 pitch is a bit steep. Now the only problem is keeping the floor dry. Just had gutters put on it, but considering a shallow french drain all the way around leaving gravel to grade. Anyone ever done this. I don't care if the grass grows up to the sides.
Anyway, thanks for the input by many of you last fall.
Tim, Ohio
TomNTex
01-16-2007 06:27:09
 Re: new barn almost finished-photo in reply to Tim, Ohio, 01-15-2007 12:03:32
Nice job Tim. That really looks nice and something to be proud of. Did you go with the grey or white on top?
Tom
Tim, Ohio
01-16-2007 15:28:13
 Re: new barn almost finished-photo in reply to TomNTex, 01-16-2007 06:27:09
Tom,
I went with the darker color on the roof.
It was called burnished slate. The sides
were called desert sand. So, it is dark
brown and tan, basically.
Tim, Ohio
Tim, Ohio
01-15-2007 13:12:48
Hey Randy,
Yes, I bought a kit from a company called
64 Metals. The cost of the kit was 8600.00
including tax. I did not buy the doors from them because I wanted to use a Wayne
Dalton brand overhead which will match the ones on my garage. Also, I prefered to buy a "man" door with a steel frame instead
of wood. 64 Metals did a good job of putting
the kit together. I only had a problem with
a piece of Z channel that was supplied white
instead of dark brown. Anyway, it was a fun
project, but I regret having done it in the
crazy weather we had in October and November.
Oh, I also added cost when I used concrete pilings
and post anchors. That added up to about another
700.00. But, at least my posts will be out of the
ground and will last my lifetime. Then I had another 300.00 in gravel. Fortunately, I did not have to rent any equipment since my neighbor is an excavator. My wife is a heavy equipment operator so she did all of the hole drilling and trackhoe work. I did a little work with a dozer to prepare the site. I would have to say using a dozer was about the most fun out of the whole project.
Tim, Ohio
Randy in Pa
01-15-2007 13:38:20
 Re: new barn almost finished-photo in reply to Tim, Ohio, 01-15-2007 13:12:48
Thanks Tim. We are trying to decide if I want a steel building or a pole building. We are going to finish the interior and install central air and heat. I dont have the time or energy to build it myself. So I will hire it done.
Randy in Pa
01-15-2007 12:14:50
Thanks for posting this. I am getting ready to build one almost exactly the same. Did you buy a kit and how much did it cost?
