Tractor Talk Discussion Forum
drain plug
Richard Baugher
01-17-2007 08:34:22
Does anyone know where the drain plug for rearend on a Farmall B is. Have looked but don't see one.
farmerjohninpa
01-17-2007 22:14:48
 Re: drain plug in reply to Richard Baugher, 01-17-2007 08:34:22
hello richard, the drain plug for the transmission housing assembly is at the rear most lowest spot on the right side of the trans. housing,, where the pto shaft housing bolts on. put your head between the right tire and look at the pto housing where it bolts to the trans.housing and about 2 inches ahead of that split,down low you will see a 1" plug with a 3/4"square hole in it,,this is the drain. now go to the left side of tractor ahead of the wheel and look at where the brake linkage from the brake shoeband, is pinned and cotter pinned, to the yoke shaft from the pedal , right there at that inter section is a 1/2"plug on the housing, this is your fill marker. and as glennster said, your fill hole plug is next to the shifter at the top of trans. on both left and right axle housings you must remove the pans to get old oil out and remove the plug just above the split of the pans and rear axle housing to fill the pans again as this hole is the fill level !! the rear axle housing use around 3 pints each, and the trans housing uses around 6 quarts, be sure to fill them by the oil level plugs though !!!!
glennster
01-17-2007 09:10:39
there are 2 drain plugs, look just inside the rear wheels, the plugs are located at the bottom of the pans. pull each plug to drain the rear gearcase. when you refill, there is pipe plug on the left side of the tractor just foreward of the shifter, on the side fill to gear oil just starts dripping out of that plug.
