Tractor Talk Discussion Forum
O/T Sea Foam Engine Treatment
Tom671
01-18-2007 04:12:51
I seen a display at the farm store selling sea foam engine treatment. What does it do? Has anybody used it, and if someone has, what where the results?
Bill in Colo
01-18-2007 19:02:46
 Re: O/T Sea Foam Engine Treatment in reply to Tom671, 01-18-2007 04:12:51
great stuff use it in my 200 lincoln welder, which can set for months between uses.usually a couple cans per year.
RJW
01-18-2007 17:49:53
When I bought my motorhome the Onan generator would not stay running without keeping the carb choked. Put a can of SeaFoam in the tank and within an hour of running she ran great. Good stuff.
paul
01-18-2007 10:59:32
Company is here in Minnesota I believe.
They have a couple products, generally solvents & stablizers to treat fuel or oil to help clean up & maintain engines under difficult or sitting idle conditions.
Everyone likes it that tries it.
I use it now & then. Nice that it works well in gas & diesel.
Used to get it for $3 a can on sales. Now it's over $5.
--->Paul
JT
01-18-2007 10:12:26
Sea Foam is the best stuff we have found for a lot of fuel related problems. We use and sel about 4-5 cases a year and have really good luck with it. If you want to know what it will do read the can, it does what the can says it will do. you will not regret it.
mike a. tenn
01-18-2007 09:59:10
i think it was originally made for winterizing boats that were stored away. i've used it to "fog" my boat engine and treat the gas left in the tank for the winter. it works very well.
Brian in Ohio
01-18-2007 07:02:10
I bought a can of the transmission treatment, but haven't used it yet. Should I expect the same results there too, or has anyone else tried it?
Steven@AZ
01-18-2007 06:08:17
Great stuff! Stabilizes fuel if in storage for an extended period of time, none of that varnish that clogs things up. You can search on google for using it to clear out carbon deposits on an engine...
Mike Freeze
01-18-2007 05:23:31
Great stuff! I have a Kawasaki generator that is not used much but recently I had to have on a job site. I got it started but was it was loping. I ran a tank of gas and a can of carb cleaner thru it but it didn"t help. My son told me about this and I got a can. I didn"t read instructions but poured the whole can in. In about five minutes that rascal was running smooth as a kitten. Still is.
dhermesc
01-18-2007 11:03:30
 Re: O/T Sea Foam Engine Treatment in reply to Mike Freeze, 01-18-2007 05:23:31
I agree, I had used B-12 in the past thinking it had to be the same stuff - if it is it doesn't act the same. I now use SeaFoam at the beginning of the season in all my small engines to clean out the varnish in the fuel system. I had an old riding mower that surging and carb cleaner and other solvents did nothing. After half a can in 2 gallons of gas the thing ran right the rest of the summer.
Weldin Man
01-18-2007 05:00:37
Seafoam is really good for engines that set a lot and aren't run very often,such as a back-up generator. put it in the gas tank and start the engine, let it run a few minutes,if the engine sets for six months and isn't started again, the gas won't go dead and it will start right back-up.Our Vol. fire departdment uses it in their pumps, generators, etc.
Bus Driver
01-18-2007 04:29:32
Lots of people like it, almost no one seems to criticize it. I bought a can. Very expensive way to get some simple solvents. Read the contents list. I have not really tested it in use.
