Tractor Talk Discussion Forum
1010 Plow
CaterpillarAl
01-19-2007 17:37:45
I have a 1010 Special that I would like to till up about 10 acres with this spring. I have a 1 bottom and 2 bottom plow. I found that I had a lot of trouble with traction on this tractor last year when trying to plow. I have 50% tires but no rear weight. I am going to try to add ballast to the rear tires. Any other ideas? Can I expect to pull my 2 16's with the right amount of traction? I am in South Central Michigan and have pretty heavy clay/loam soil.
2nd question is that much of the area I want to till is planted in either grass mix or clover mix right now. Do I have to spray? Can I plow it under and replant? I want to minimize spray, but I know I won't eliminate it.
jhill52
01-20-2007 06:34:13
 Re: 1010 Plow in reply to CaterpillarAl, 01-19-2007 17:37:45
2-16s will be everything that 1010 can pull. you may need some weights in adition to loading the tires. Timing is important. I was raised in the area and the soil has to be the right moisties not too dry or you won't be able to touch.
Spray everything with round up and you will kill what is growing. You will however plow up a new batch of seeds you will need to control.
Good Luck
Jerry
