Tractor Talk Discussion Forum
Diesel fuel in oil
NCCub
01-19-2007 22:46:22
I have a bolens (Iseki) compact diesel tractor, changed the oil, it appears there is diesel fuel in oil, normal or?
JOHN HARMON
01-20-2007 13:59:46
 Re: Diesel fuel in oil in reply to NCCub, 01-19-2007 22:46:22
I'm not familiar with this Tractor but I asume it is a small one and does not come equipped with a Turbo Charger.If it was so equipped I would have the turbo seals checked. One of my turbo equipped engines had a bad Seal and it near filled the crankcase with raw Diesel Fuel.See Ya'John
J. Schwiebert
01-20-2007 09:25:20
How much fuel in the oil? How does it run? do you have any white or grey smoke? You could have anything from a compression problem on one or more cylinders to a bad thermostat to several items in between. I also sent you an e-mail. J.
NCCub
01-20-2007 13:11:11
 Re: Diesel fuel in oil in reply to J. Schwiebert, 01-20-2007 09:25:20
no smoke, runs great, good power, seems like a small amount of fuel in oil, based on smell, consistency.
Kerry
NCCUb
01-20-2007 07:10:21
It has an injection pump, engine runs great no problems.
Kerry
Shovelman
01-20-2007 04:24:26
If the engine is equipped with a mechanical fuel transfer (lift) pump, remove it and test for leaks. A punctured diaphragm will sometimes allow fuel to leak into the crankcase.
Good luck,
Scott
marlowe
01-20-2007 04:22:00
seal in injector pump drive is out or if you have a fuel pump on it that has a leak. if it runs right it's not the injectors. it's the fuel pump [if] it has one other wise it's the injector pump seal
Vern-MI
01-20-2007 04:06:16
Injectors are leaking during shut down period. Fix injectors before the bearings and cylinder walls are scrap.
