Tractor Talk Discussion Forum
nhc 250 cummins water pump belt
kyler27
01-20-2007 08:14:52
does anyone know how to tighten the water pump belt on a 73 nhc 250 cummins diesel
Merlin in Saint Louis
01-20-2007 09:38:42
 Re: nhc 250 cummins water pump belt in reply to kyler27, 01-20-2007 08:14:52
Hello! I used to work for Cummins in Saint Paul, MN as a Field Service generator technician. The NH is an older engine, and if I remember correctly...the water pump belt is tightened by rotating an eccentric/cam. There is a gasket ring around the pump, where it mates to the block. You will have to loosen the pump mounting bolts, then take a prybar and rotate the pump in its housing. Initially, you may have to knock the pump loose with a punch and a hammer. The problem is that once you do this...you will have a coolant leak. To do it "right"...you might have to drain the cooling system and install a new water pump gasket. It is not a fun job. Hopefully, you can rotate the pump without damaging the gasket. Then just tightem the mounting bolts. My suggestion is to try adjusting it first. If it leaks, then you will have to tear into it. By the way...what is this engine installed in? Not too many of them around anymore: they were a good, solid engine in their day. Best wishes!
Merlin
kyler27
01-20-2007 19:07:33
 Re: nhc 250 cummins water pump belt in reply to Merlin in Saint Louis, 01-20-2007 09:38:42
thanks ive messed with newer cummins that have the tensioner pulley but not one like this its in a 73 gmc tandem dump truck i just bought its alittle ruff but i like to tinker on stuff and it only cost 1500 so i think i was a deal thanks again
