Tractor Talk Discussion Forum
Duner WI: Herc JX headbolts
noncompos
01-20-2007 22:25:27
Duner: Made a note to contact you but it got covered up. Would you please advise the pub date of your Motor manual so I can note the Herc headbolt differences in mine. Mine shows HX Series 105 lbs; JX,RX,YX Series 75; QX,WX Series 60, and RXL 80. Text refers to "...the nuts or bolts..." and does not show different lbs for nuts or bolts. Many thxx!!
Duner Wi
01-21-2007 15:20:15
 Re: Duner WI: Herc JX headbolts in reply to noncompos, 01-20-2007 22:25:27
Well I was quoting from First edition copyright 1943 and does not say when printed. My fouth edition does say the numbers you quote. Text say draw the nuts and bolts down evenly, repeating the operation until normally tight. After the engine has been run long enoughto warm it up a final tightening should be made with a torque wrench. I don't know which #s are correct.
noncompos
01-21-2007 21:29:45
 Re: Duner WI: Herc JX headbolts in reply to Duner Wi, 01-21-2007 15:20:15
Duner, thxx for info, but, if you don't mind, could you answer another question for me? My 50 issue covers 36-49, and I've been wondering whether to pick up an earlier issue. Mine has the pages for most orphan trucks, with a page showing models, years and engine used (Schacht 40A 36-38 Herc YXC3). Does your 43 have this type of info, and if so what years does it cover?? Some pix I've seen look different, and I haven't turned one up here to look at. Feel free to email. Many thxx!.
Duner Wi
01-22-2007 16:39:31
 Re: Duner WI: Herc JX headbolts in reply to noncompos, 01-21-2007 21:29:45
My first edition covers 1936-42 and is format is quite different from the 1951 book. for instance the Schacht in the first edition list the Continental engine on page 32 and the Hercules engine on page 99. Bork and back clutch on page 704. Transmissions on page 717 and so on. So if multiple makes used the Hercules engine you go to the Hercules engine section and get info. The 1951 book lists Diamond T and your Hercules info is there. I like the earlier book better but the later book has info the earlier book does not have regarding model # of trucks. You really should have both don't you think??
noncompos
01-23-2007 21:22:17
 Re: Duner WI: Herc JX headbolts in reply to Duner Wi, 01-22-2007 16:39:31
Duner, many thxx for reply and info. Yeah, they probably changed the various editions enough so that even though most info overlapped there was enough to sell more manuals; I think they call it marketing. Take care. Bud
noncompos
01-21-2007 13:47:36
John and BDT: Many thxx for replies; even knowing figures are confusing is better than thinking the Motor figures are correct. John: thxx again, but don"t need sequence; I"d sent my figures to Scott (slh) who asked for torque amounts and sequence on his 1-15 "Herc Headbolt Torque" post, and he"s probably got it back together by now. (Hopefully without twisting anything off!!)
J Schwiebert
01-21-2007 05:23:00
Bud: I will muddy the water some more. According to Oliver for a Crawler application for the JX(D) engine, Torque valves are as follows: Screws for manifold side 80 pounds,Center row and row opposite manifold side 90 foot pounds retorque after 50 hours. I can U. S. Mail you there torque sequence diagram.
J Schwiebert
01-21-2007 06:13:40
 Re: Duner WI: Herc JX headbolts in reply to J Schwiebert, 01-21-2007 05:23:00
Post above thi is for cap screws, one below is for studs. J.
J Schwiebert
01-21-2007 05:27:34
Bud: In my Hercules manual for the JX engines (however book is for the four cylinder engines only) Screws marked 1041, value is 100 foot pounds. Screws marked 30-37 are either 75 or 85 depending on their position in the engine.
BDT in Minnesota
01-21-2007 05:13:35
1980 Motors Manuel....Herculies model JXC, JXD, JXLD...headbolt torque:nuts 65, screws on manifold side 75, screws marked "1041" 100, other screws 85.... Small world!! I glanced at these specs aboul 15 minutes before I seen your post..I scanned the entire page and tried to get it on here but lol...e,mail would maybe work better--- if ya need more specs--just yell--time for me to finish learning how to drive the rest of these computer programs,,,,after I get some sleep..Bdt in MN..
