Tractor Talk Discussion Forum
OT- injectors for 8v71
JoeBob/IN
01-21-2007 05:26:24
I have been given a "74 GMC tractor with an 8v71 non-turbo! Problem is it needs at least 4 injectors, all on the right bank will fire but all on the left bank remain cold untill you really get it warmed up and even then I don"t know how many are actually working. Anyways, it had C60"s in it but I was wondering what others I could safely put in to bump the power some. Seeing as I have to replace them anyways why not get more bang for my buck right? So what others will work without burning a hole in the pistons or melting them down? Remember, it is a non-turbo which I assume that will make a difference. Thanks!
NC wayne
01-21-2007 17:34:22
 Re: OT- injectors for 8v71 in reply to JoeBob/IN, 01-21-2007 05:26:24
I've been working on Detroits on and off for about ten years now and I don't claim to be any kind of expert, there are simply too many different combinations to even try to remember them all. I simply go by the book to set them up so there are no problems. If a customer wants to "soup one up" after I'm gone so be it, I don't want the liability of paying for a rebuild when it blows up on them. One thing right off, if you change the injectors change them as a full set or 8. Doing otherwise will create an unbalanced load within the engine and almost certain damage to it. One thing before I go any further though,I don't understand why your thinking the injectors are the blame for the one bank not firing when cold. Then injectors are cam operated so they should inject fuel wether their cold or not. In fact if it were an injector issue they would more than likely inject less as internal clearances expanded allowing fuel to bypass around the plunger as they heated up. Sounds to me more like low compression on those cylinders more than anything else. Personally I'd have the compression checked and see what you get and if it checks out OK then have it properly tuned up before doing anything else..... That said I did a search of my Field Service Data Book to see what could be done "by the book" with a naturally aspirated 8V71. For those that say a Detroit isn't "naturally aspirated" but blown, I know this, but they consider non-turboed engine as naturally aspirated since the blower is an intergral part of all of the two stroke engines. Anyway, here's what I found for you. First the book doesn't list any 8v71 engines under the automotive section, just the V92 series. All the otner 71 series automotive rated engines were inlines. The only place I found 8V71's was in the industrial and marine sections. There is one page of them listed in the industrial section that are non turbo versions, and the highest HP shown is 305 @ 2100RPM , and that's with a 7N65 injector with the timing set at 1.484. Step back to a C65, N65, or 7E65(@ 2000 RPM vs 2100), all with the same timing and the HP's are to 304, 284, and 283 respectively. Now the final HP rating is also gonna change in regards to the accessories attached to the engine. The book shows it like this, "three" engines, two with N65 injectors, timed at 1.484 and the third at 1.460. The two with the 1.484 timing are rated at 272 and 294 HP, the third is rated 304HP. The book annotates these three engines saying they are "the same engine" with different accessories attached. None of these, engines, in any rating, have anything showing the blower being either over or under driven in relation to standard as one post suggested. Like I said this info is straight out of the book. Not to say there's no such thing but I personally have never heard of or read in any of the manuals we've got about a "B" setting on the injectors. The injector type determines the amount of fuel injected per stroke and the timing does just that, it times the injection of that set amount of fuel in relation to the stroke of the piston. On every two stroke engine I've set up, be they inline or V, you always set the injector rack at full stroke in relation to the governor. I other words if you floor board the throttle the rack pushes all the injectors to a full fuel position and they do just that, give full fuel output, til the governor takes over and pulls the rack back when the needed fuel amount is reached in relation to the upper RPM limit set in the governor mechanism. Now there are throttle delay issues involved with the automotive style engines that are designed mainly to cut down on smoke/reduce emmisions when accelerating but that has no effect on the engines final HP output. That limit is gonna be based on the size of the injector and how much fuel it can provide the engine to burn in relation to the amount of air it can pull in to burn, all at a given RPM. Like I said in the beginning I'm no expert, but I don't see how your gonna make 350HP out of your engine as one post suggested. I'm not saying it can't be done without a turbo, but it's a long way from 305 to 350 as HP goes. Now of you had a turboed (8V71T) engine you could bump the HP to 413@2100 RPM using a N90 injector set at 1.460 and a TV8101 or with a turboed and aftercooled (8V71TA) engine you could bump it on up to 520@2300 using a M95 set at 1.484 injector and a TV8513 turbo..... ..Again I'm no expert when it comes to Detroits but the info I've provided is straight out of the Mfgs data book so you can use it and feel safe that you won't damage your engine. Good luck.
JoeBob/IN
01-22-2007 05:01:01
 Re: OT- injectors for 8v71 in reply to NC wayne, 01-21-2007 17:34:22
The reason I thought it might be the injectors is the guy I got if from had a buddy messin with it and claimed he replaced a few injectors. I did find one that most definately is recently rebuilt and several that look older than the rest. I assume the tips are dirty on the bank that isn't working which is causing a bad spray and causing it to not burn correctly until it gets hot enough to more correctly burn the fuel. So I guess I will swap the injectors side to side and see what I get if I don't get a chance to take them to a diesel shop. Thanks for the great info.
buickanddeere
01-21-2007 12:19:01
C70's instead of N70's. The California injectors burn cleaner,start better and make the same HP. With injectors that size the blower should be crankd 5% over speed.
chiefrunamuk
01-21-2007 11:36:29
JoeBob/in; 8v71 don't have turbo, they have a blower, does same thing,looks kinda like a pregnant intake manifold, put in 8 new n60 or 65 inj. have a good detroit dsl man run the "rack", good to go.Detroit Dsl driving tip; when you get ready to drive it slam your hand in the door first then drive it like your mad it(the truck),drove Detroits for years, just keep it tached out, Ken
JoeBob/IN
01-22-2007 04:56:21
 Re: OT- injectors for 8v71 in reply to chiefrunamuk, 01-21-2007 11:36:29
Yeah I realize it doesn't have a turbo and I realize it has a blower and also why it has that blower. Now we do have a 6-71 that does have a turbo.
Jack in Fla
01-21-2007 07:05:35
JoeBob, If you put new injecters into the motor put N-70, (9 hole), this will make 350 Horsepower. And do like the other post said, I had one set like that and was a good motor, 8V-detroit is not as bad as everyone makes out to be, if they are set up right. Also there are two timings to set them at, (known as "a", "B") set it on "B", big difference, but the rack and injecters have to be set right with special little tool. Jack
Jim WJ
01-21-2007 06:32:37
See if you can get a copy of detroits field service data book. You can get it from a detroit diesel dealer. This will have all kinds of information on the 2 cycle, injectors, tuneup settings, fuel pressures, etc. I would not recommend mixing different size injectors.
JoeBob/IN
01-21-2007 10:01:45
 Re: OT- injectors for 8v71 in reply to Jim WJ, 01-21-2007 06:32:37
If I were to get different sized injectors it would be all 8, wouldn't be good to have different sizes in there I wouldn't think!
