Tractor Talk Discussion Forum
Gresen TB Hydraulic Pump Filter question
Twigs
01-23-2007 21:15:37
Hi- I purchased a used tractor and it has a Gresen TB Hydraulic pump and as far as I can tell no hydraulic filter. I assume I should install a filter. Is this correct? If so, what filter should I install? Do you install the filter on the incoming or outgoing Hydraulic hose? Thx
glennster
01-24-2007 05:57:01
 Re: Gresen TB Hydraulic Pump Filter question in reply to Twigs, 01-23-2007 21:15:37
pick up a filter block and filter at your local farm supply. mount the filter after the cylinder control valves where it returns to the resevoir tank. if you mount it on the pressure side, as soon as you use the valve, the pressure will blow the filter off.
