Tractor Talk Discussion Forum
PHOTO - a topper
David in Wales
01-26-2007 13:11:52
third party image
Hi Gang;
Over here the single bladed heavy duty rotary mowers are not big sellers. Yes they are cheaper to make and great for cutting really rough and woody vegetation. But they dont lave a nice finish.
So the most common type of rotary mowers are known as TOPPERS. This name comes from their primary use in trimming off dead stalks & tufts of grass from pastures - ie topping the growth.
This is a Teagle version with twin rotors with swing back & sharpenable tips. The rotors are staggered to give blade overlap. The headstock has centre mount or offset to right side of tractor to take out tractor wheel mark.
The height is adjusted by rebolting side skids up or down.
Various widths of single units are made to suit tractor PTO power. The gearbox is protected with slip clutch in the PTO shaft. Some are dirrect drive from gear box to rotors, others drive by V belts.
Cheers David
Bob
01-26-2007 15:28:12
 Re: PHOTO - a topper in reply to David in Wales, 01-26-2007 13:11:52
A hundred miles east of me, in the Red River Valley of the North, they use drum-type defoliators to remove the tops of sugar beets before harvest.
They use rubber flails swinging from a drum, often followed by swinging scalping knives.
#%$& really flies at random when on of these is in use!
Third Party Image
RonND
01-26-2007 16:07:28
 Re: PHOTO - a topper in reply to Bob, 01-26-2007 15:28:12
Ahh yes, the sugar beet roto-beater. They work great to lay down the sugar beet greens between the beet rows so the beet lifters can dig the beets without (hopefully) adding the greens in the beet truck. Mix in a little moisture in the heavy soil of the RRV and the roto-beater can get pretty heavy with mud.
In the RRV there is usally a 2 week window from Oct 1 where the farmer brings the beets to the local pile. Then the beets are hauled to the processer in the winter and all beets should be at the processer by May of the following year. Of course Mother Nature does her best to cooperate...sometimes.
David in Wales
01-26-2007 14:15:24
Hi Gang;
We get Rhino bat-wing mowers here too. Alamo ownes McConnel, Spearhead, Twose, & Borford Turner in England who are old established makers of flail hedge cutters & rotary mowers. Most the the big bat-wings are sold for grass cutting air fields & large open space municipal areas.
Yippee - a photo of a Ford tractor on YT Forum at last !!!
Cheers David
Jonfarmer
01-26-2007 13:44:35
third party image
Lots of folks over here buy the 5ft-8ft rotary cutters becuase they:
1) have just a small tractor and just a few acres to do.
2) the larger mowers are only good for mowing in big open spaces.
Thats why the smaller ones are the most used and talked about here, but they got huge flex fold ones availible. I know John Deere, Rhino, and Bush Hog make them up to 15 feet wide and from models made to cut grass only to heavy duty brush.
When I looked up this picture, it says Rhino makes them up to 20 feet wide!.
