Tractor Talk Discussion Forum
Allis WD
Bob Drown
01-27-2007 13:44:16
My son just called from Oklahoma, he just got an Allis-Chalmers WD
The seral # is WD274796GA
Can someone tell us approx what year it is?
Thanks,
Bob
JMS/MN
01-27-2007 20:25:16
 Re: Allis WD in reply to Bob Drown, 01-27-2007 13:44:16
Might be a confusion on numbers..... ....when you see GA--did that come from the engine?, not the differential? G would indicate gas, rather than the other engine options. If the serial number on the differential is WD 274796..... ....sorry- WD45 went to 236958,,,,, ,,, so it is not a WD45. You must be looking at an engine number...of a WD. Check on the rear vertical face of the left side of the differential for a number. Starts with WD, that is the tractor serial number.
omahagreg
01-27-2007 14:11:51
Norm Swinfords history of AC shows that must be a wrong number. He shows the last WD45 of 1957 (last year) being numbered 236958.
Greg
Bob Drown
01-27-2007 15:09:22
 Re: Allis WD in reply to omahagreg, 01-27-2007 14:11:51
Here is another number that he gave me
203937
Thanks,
Bob
Brian G. NY
01-29-2007 07:33:13
 Re: Allis WD in reply to Bob Drown, 01-27-2007 15:09:22
The first number you gave us is definitely a "WD" engine number; built sometime in 1950. All WD-45 engine numbers begin with "45". If this second number came off the rear differential and was preceded by WD, then the tractor (or the differential, at least) was built in 1955. If the shift lever is straight, I would guess the tractor is a WD. If the shift lever is curved, it could be a late (mid-52) WD or a WD-45. There are lots of these tractors that have had parts replaced over the years so it is sometimes difficult to pin down the "birthdate" of the original tractor.
Bob Drown
01-29-2007 07:38:37
 Re: Allis WD in reply to Brian G. NY, 01-29-2007 07:33:13
Brian,
Thanks for the information, Whereabouts in New York.
I live in the Catsills,
Thanks again,
Bob
omahagreg
01-27-2007 15:32:53
That number would be a 1955 WD45.
Greg
