Tractor Talk Discussion Forum
Stereo Amp question?OT
Jak
01-29-2007 09:24:24
My son installed an amp in his truck and had played fine for a while.He took it out to use in a car for a bit and after a couple hours of working fine he turned down the stereo and when turned back up it didn't work anymore.It has a protection light on now.What could be wrong with it,could it be cleared or repaired?Thanks for some info.
Janicholson
01-29-2007 10:06:34
 Re: Stereo Amp question?OT in reply to Jak, 01-29-2007 09:24:24
I would guess that it has internal fuses. Possibly a breaker, but more likely fuses. The systems can react to accidental disconnect, shorts, and improper impedence with fuse blowing. If there is documentation, read it, or google the company for info on repair. JimN
Jak
01-29-2007 11:34:18
 Re: Stereo Amp question?OT in reply to Janicholson, 01-29-2007 10:06:34
Thanks.
Jeff Oliver
01-29-2007 16:49:11
 Re: Stereo Amp question?OT in reply to Jak, 01-29-2007 11:34:18
Jak call brandon, he fools with that sutff all of the time and can probably tell you or figure it out. With all the crap he has in the trunk of his car he oughta be able to!!!! Did i tell you he pulled up here one night and literally shook the plates above out kitchen counter tops? And wasn'nt all the way up the driveway!!!
