Tractor Talk Discussion Forum
706 Diesel RPMs
Robert Searcy
01-30-2007 12:11:00
What were the max RPMs on the 282 diesel used on the 706.
I have found the hp ratings and such on tractor data but I cannot find any engine speed info
Robert Searcy
01-31-2007 06:51:29
 Re: 706 Diesel RPMs in reply to Robert Searcy, 01-30-2007 12:11:00
What is the difference between speed advance and load advance??
Man did I open a can of worms - now I am really curious
low budget
01-31-2007 10:10:35
 Re: 706 Diesel RPMs in reply to Robert Searcy, 01-31-2007 06:51:29
Most injector pumps use an advance device to improve fuel economy simular in theory to spark distributors on gas engines. "Speed advance" advances the injection timing as engine speed increases, "load advance" advances the timing under light loads. I assume IH chose to use load advance on the 656 because the engine turns slower.
Robert Searcy
01-31-2007 11:19:34
 Re: 706 Diesel RPMs in reply to low budget, 01-31-2007 10:10:35
So I presume turning up a 560 to 2800 rpms like the 660 or combine engine is totally out of the question as it probably had no timing advance to it at all??
djm75
01-31-2007 00:04:12
theres only 2 ways to get more power out of a diesel more air like turbo or supercharger or more rpms everybody has there choice sometimes they do both.
Robert Searcy
01-30-2007 20:38:00
holy smokes, did they do anything different with the cam or pump for that 2800 rpms, i wonder if someone could turn up the throttle linkage/stop on a 656 or 706 without adjusting the injector pump internally and get that kind of rpms and hp out of it
anyone have any idea??
low budget
01-30-2007 21:02:43
 Re: 706 Diesel RPMs in reply to Robert Searcy, 01-30-2007 20:38:00
Uses a different governor spring, also a 656 has "load advance" and a 706 and combine engine have "speed advance" The actual fuel delivery in volume per revolution is the same for all three engines. I know this because a friend has his 656 set up to 706 specs.
Gene Dotson
01-30-2007 17:23:07
Bob;
My 1959 IH 660 uses the same 282 engine and rated at 84 horsepower at 2800 RPM... Gene
jdemaris
01-30-2007 13:08:36
Rated RPM is 2300.
Robert Searcy
01-30-2007 13:39:44
 Re: 706 Diesel RPMs in reply to jdemaris, 01-30-2007 13:08:36
holy smokes, i would have never guess that, i was thinking like maybe 2000 for a diesel, i know the 560 rpms are like 1800 and a HP rating of 60, and i figured maybe 1900 for a 656 at 65 hp but never thot a 282 diesel would be turning 2300 for 72HP
Bob
01-30-2007 17:21:47
 Re: 706 Diesel RPMs in reply to Robert Searcy, 01-30-2007 13:39:44
Youn think THAT'S fast? When used on a combine, high idle was 2810 RPM's!
jdemaris
01-30-2007 13:51:47
I am by no means an IH expert - just going by Nebraska test results. Test # 856 done in 1963. 706 diesel, 282 c.i., etc. At rated engine speed of 2300 RPM it put out 72.4 horsepower. When tested with the 1000 RPM PTO it was run at an engine speed of 2072 RPM and put out 67 horsepower.
Robert Searcy
01-30-2007 13:55:58
 Re: 706 Diesel RPMs in reply to jdemaris, 01-30-2007 13:51:47
sounds terrific, thanks for the info, i had no idea they turned that much, i used to run a 706 gasser with the larger 312 i believe or something like that engine for a farmer when growing up and it turned pretty high if i remember right, it was a gasaholic though, i would fill it up in the morn and add more at lunch to get me through the rest of the day if i was working it hard, my boss had an 856 diesel adn he could run all day and never fuel
