Tractor Talk Discussion Forum
Help!!!!!
Devin Sparks
02-03-2007 10:06:00
I have a MF 3525 a 100 HP tractor. I started it up several weeks ago and after it had ran for a little while I noticed that it was leaking hydraulic fluid under the tractor. I tried it again today and the same thing. It is leaking out from where the carter pins are. Any idea what has gone wrong.
Thanks
Devin
Roy Suomi
02-03-2007 17:09:24
 Re: Help!!!!! in reply to Devin Sparks, 02-03-2007 10:06:00
By the carter pin , huh? Is that anywhere near the clutch housing behind the engine?? If so , I'd say there's a problem with the transmission pump inside there...If there's no access covers to take off so you can get a better look , you might have to split the tractor to see whats leaking....
Devin Sparks
02-03-2007 17:41:21
 Re: Help!!!!! in reply to Roy Suomi, 02-03-2007 17:09:24
Yes it is behind the engine. There is a cover there and that where the fluid was pouring from first. I have also lost pressure to the clutch pedal. Still think it could be the transmission pump?
Thanks
Devin
richard in nz
02-04-2007 00:24:51
 Re: Help!!!!! in reply to Devin Sparks, 02-03-2007 17:41:21
The clutch slave cylinder or the pipe to it has failed, you will have to split to repair.
