Tractor Talk Discussion Forum
johndeere D
greg depuydt
02-03-2007 14:50:48
I need to locate a set of rod bearings for a 1936 Model D john deere. they are not avail. from dealer and I believe there must be a source that other people have used.
430WLPG
02-03-2007 20:04:45
 Re: johndeere D in reply to greg depuydt, 02-03-2007 14:50:48
Some D's used a replaceable babbit insert type rod part# AD671R and I think they fit the D103R rods,is that the # rod you have? I think I have a set NOS, but I'd have to check. Let me know.
greg depuydt
02-04-2007 14:09:08
 Re: johndeere D in reply to 430WLPG, 02-03-2007 20:04:45
thankyou 430wlpg. rod #D1601R crank #D1750R tractor serial#128329
Gene Davis (GA)
02-03-2007 18:48:28
This engine should have babbit bearings from the factor unless some one went to a lot of trouble and expense to change them to an insert type. The rods with babbit are usually adjusted by shims if the crankshaft is in good round condition.
