Tractor Talk Discussion Forum
Corn........
Brad Wright of
02-03-2007 15:09:32
How far apart do you usually plant your rows for corn? Lookin at planters and needed to know how much room it needed. I figured someone on here would prolly know.
two mile
02-04-2007 06:07:35
 Re: Corn........ in reply to Brad Wright of MO, 02-03-2007 15:09:32
30" rows are standard. We have a neighbor who still uses 36" and I see one distinct advantage. He can start sidedressing fertilizer several days earlier without the risk of throwing dirt on the row.
Leland
02-03-2007 19:58:05
Most is in 30" rows today if you don't have your own combine you better find out what guys that do custom work in your area have ,some places still plant in 36-38 " rows
edchainsaw
02-03-2007 17:59:16
30in is what you want.. shades the ground sooner
and the seed corn companies tell you (lol all the way to the banks) that higher population makes higher yeilds... and the way to do that is narrow the rows down... I have a cousin that is planting 20in rows...
skip33652
02-03-2007 18:19:00
 Re: Corn........ in reply to edchainsaw, 02-03-2007 17:59:16
just cause a dealer is selling more corn don't mean the farmer is making more money,even if his yield is higher .
If your seed won't make 8-9 bushel per thousand plants per acre you should maybe change brands. at 7 bushel per thousand you need 21,500 plants per acre to make 150.Paul
kyhayman
02-03-2007 17:25:32
I've planted 38's conventional and 30's notil. Really never saw a difference in yield between the two. For me, about 135-150 bu per acre was what it was, pretty normal for this area.
phillip d
02-03-2007 16:49:59
most planters should be adjustable to an extent.30" works best with a standard spaced tractor
ejr-IA.
02-03-2007 15:33:07
The rows have been getting narrower through the years.Horse rows were 42'' then came the tractors at first they were 40''then 38''now 30'' is the most common.
