Tractor Talk Discussion Forum
F250 truck weight
fordpullr
02-06-2007 19:40:32
i have a 1985 F250. it has the 460,long bed regular cab,a dana 70 in the rear and a dana 44 in the front.anybody have any ideas on what it might weigh?
davpal
02-06-2007 21:11:38
 Re: F250 truck weight in reply to fordpullr, 02-06-2007 19:40:32
5500 lbs plus or minus 100 lbs. I had a 76 with a 460 and currently have a 88 with a 460. That is what they both weighed. You can go to the elevator and do it for a couple bucks.
old
02-06-2007 19:53:55
Should have it listed on the inside of the drivers door.
john cub owner
02-06-2007 20:20:03
 Re: F250 truck weight in reply to old, 02-06-2007 19:53:55
Aren't the numbers on the panel maximum? Take it to your local feed store and weigh it, they will only charge 2 or 3 dollars. I would suspect it to weigh around 8 or 9k.
varmint
02-07-2007 08:47:53
 Re: F250 truck weight in reply to john cub owner, 02-06-2007 20:20:03
maybe 6 they were bilt prety lite
Leroy
02-07-2007 19:24:08
 Re: F250 truck weight in reply to varmint, 02-07-2007 08:47:53
Mine is an 86 F250 2 wheel drive and it is heavy, only a 351 but I have an 8600 GVW and it sets on 10 ply tires.
old
02-06-2007 20:26:24
The ones I have seen give both the weight of the truck and also what max is also.
