Tractor Talk Discussion Forum
Massey Ferguson steering problem
Kokanee
02-07-2007 15:22:38
Hi I bought a MF 275.I believe its a 1985 model. The steering wheel turns freely but no movement in the front wheels. The front wheels however will turn when the front end is lifted but not as quik as they should.
The fella I bought it off says it steered ok when he parked it in the fall although it was abit stiff. When I turn the wheel about 20 full turns abit of fluid spits out of from under the steering wheel. When I stop turning the wheel I can hear the fluid returning to the pump...if this means anything.
Any ideas on where to start would be really appreciated. Thanks
LBSMJS
02-07-2007 16:49:57
 Re: Massey Ferguson steering problem in reply to Kokanee, 02-07-2007 15:22:38
Unhook the tierods from the spindle arm & be sure you don,t have a spindle real stiff.Had this happen on a 1135& a 1155.
ben brown
02-07-2007 16:32:17
this model tractor has a power steering pump on left side of tractor. check fluid in it there should be a fill plug on top of pump takes about 2 to 3 quarts depending on how empty it is.
