Tractor Talk Discussion Forum
Delco Remy Generator Questions 6v or 12V?
Gene Cockrell
02-10-2007 11:19:45
Hi, I saw your website and thought to take a shot at asking a question I need answered. This concerns old Delco-Remy tractor generators without ventilation (closed case). Questions are: First, how can one tell if you are looking at a 6 or a 12 volt generator if you have it apart? I am trying to convert an ancient Allis Chalmers B tractor (1940 model, positive ground, magneto ignition) from a 6 volt to a 12 volt system without having to use an alternator but rather a 12 volt generator to maintain appearance. With this said, what I have now is a functioning 6 volt Delco system with a voltage regulator fitted to the generator instead of the original cutout and high/low range switch (switch was burned when I got the tractor). I have another generator given to me which is supposed to be 12V (from a Case) but after cleanup had a rebuilders' tag indicating that it's 6V. This generator (of course) has no manufacturer's number plate so I am stuck. Now, I have both units disassembled. I note that the field coils' center plates on the "12V" unit are a bit larger than the 6V unit I removed from the tractor. I also note that the "12V" unit's armature rotor windings seem to be in a different direction than on the 6 V unit. How do I know if it's a 6V or 12V unit that I got given?
Second question is: Does direction of rotation make a difference when dealing with generators? thanks for any advice or enlightenment...
The 6V system I currently have is just not up to the cranking task which is why I want to replace it. I do have the heavy duty 6V cable and ground strap installed and a fairly new battery. I have to jump start the tractor almost anytime for a hot start which is really aggravating. ///Gene Cockrell
John T
02-10-2007 11:58:42
 Re: Delco Remy Generator Questions 6v or 12V? in reply to Gene Cockrell, 02-10-2007 11:19:45
Gene, I have used 6 volt gennys to charge at 12 volts simply by replacing the Voltage Regulator to a 12 volt, Im NOT saying thats the best or engineering correct way to do it or that it sets the world on fire as far as a high charge rate, Im ONLY saying it worked. A genny dont necessarily know what voltage to produce, it increases by turning it faster and/or pumping more current (within limits) through its field windings. If you have a 3 brush genny adjust its third brush to max charge position.
If a 6 volt sytem dont crank satisfactory I first recommend the biggest heaviest highest rated battery that physically fits in the box and the use of 00 Gauge battery n starter n ground cables. Be sure n remove n clean n wire brush n reattach each n every battery n starter n ground n cable n switch/solenoid connection but if she still cranks slow you may have a starter/solenoid problem or finally the starter itself is bad. If the ground is to any thin wimpy or rusty sheet metal component, reattach it to a clean soild frame type bolt.
Dont forget any ignition modifications (ballast resistor or 12 volt coil) if you change to 12 volts and gauges n lights etc and ground polarity.
John T
Bob M
02-10-2007 11:56:44
Gene - A couple thoughts:
1 - If generators are otherwise identical, the resistance of the field windings on a 12 volt generator should be about double that of a 6 volt. (Note: As field winding resistances are quite low in both cases you'll need an ohmmeter capable of reading to 0.1 ohm - ie. a digital voltmeter - to accurately measure winding resistance.)
2 - Generators ARE rotation sensitive. Brushes are positioned - and often also angled - for operation in only one direction (usually clockwise when looking at the drive pulley)
Incidentally converting to 12 volts to deal with a slow cranking condition is only a temporary, "bandaid" fix. Your Allis should spin over just fine on 6 volts if everything is up to snuff. Requirements are good battery, suitably heavy battery cables (not the cheap "12 volt" cables like are sold in auto parts stores...), a good starter switch and of course a healthy starter.
Gene Cockrell
02-11-2007 14:53:11
 Re: Delco Remy Generator Questions 6v or 12V? in reply to Bob M, 02-10-2007 11:56:44
Cool, so the field coil windings should be of a finer gauge wire than on the 6V system. (I have a pretty good multimeter)
However for the rotation question, is it only the brush plate that"s timed different for LH or RH rotation or is the rotor assembly obviously wired diferently?...Thanks for the info.
BTW The starter on the tractor is fine, I have gone through this and it is in a good way. I have good cables (tractor cable) ground strap, connections, etc. I"m not cutting corners here.
When one hits the starter with 12V, the sucker spins. With 6V, unless it"s just off a battery charger you can"t get one complete revolution of the engine. Fortunately, the tractor if cold will always start by being bumped. I suspect this has to do with the engine. I rebuilt the thing a few years back and to get the head/block mating surface squared up, we had to machine almost 0.200" off. This has affected the compression ratio and I assume that this increased (from 5.7:1) compression combined with a marginal electrical system is the root of the problem. Like I say, when jumped with 12V, the starter cranks over like a BMW.
Gerald J.
02-10-2007 11:45:10
If wound for the same shaft speed, a 12 generator armature and field will have smaller wire than a 6 volt. Ratio of about 1.4:1 diameter, 2:1 cross section.
Shaft speed complicates things. Holding the same field excitation, simply turning the shaft twice as fast on a 6 volt generator makes 12 volts. Increasing the field current with shaft speed held constant increases the output voltage. That's limited by the magnetic saturation of the field cores along with the armature core.
The angle of wires leaving the commutator depends on which layer was put on last but it can affect the brush position.
The 6 volt starter worked for decades. If if won't crank with heavy duty (How heavy? 00 gauge is heavy, 2 isn't.) cables and battery, then there is need for starter attention. I believe in replacing bearings as well as brushes and solenoid and Bendix. Worn bearings (usually bronze bushings, simple sleeve bearings) let the armature drag on the pole pieces and that really kill shaft horsepower. When brushes are replaced they need to be sanded to the contour of the commutator and that commutator should have been turned and then the micas cut so they aren't touched by the brushes. Driving a worn out starter with 12 volts is like kicking a dead horse, doesn't make it work that much better for long.
Besides sturdy cables, the connections need to be clean through out the starting system.
Gerald J.
Gene Cockrell
02-11-2007 15:23:43
 Re: Delco Remy Generator Questions 6v or 12V? in reply to Gerald J., 02-10-2007 11:45:10
Hi Gerald, thanks for the reply. I have a quick question though. You mention something about field core saturation; would this show up as a field coil with a lot larger core for the 12V field coil than for the 6V?
Now, the field coils on the old 6V unit show 1.9 ohm resistance across both coils, the questionable unit has new field coils, I didn't want to start cutting covering but they test 6.9 ohms across both coils. Now for the rotor. The 6V armature windings are about half the wire diameter of the questionable (12V?) unit's windings and not the other way around. (Number for the original 6V rotor is 853593- I cannot see a full number for the "12 V" unit). Are you sure that the rotor windings are supposed to be smaller diameter for the 12 V unit? Actually the starter is in a pretty good way. Overhaul with bushings and brushes and a new contactor-bendix was excellent. I have good cables on the tractor, a special thick tractor "hot" cable from the battery to the starter contactor and a thick ground strap. All connections are filed and greased. Bypassing the tractor ground with jumper cables grounding directly to the starter makes no difference. When that starter is hit with 12V it cranks the engine like a BMW. With 6V I can't get the engine to turn through a complete revolution. Fortunately this is enough if the engine is stone cold, it fires right off. As for the battery size, this is an Allis B and it has a pretty small battery box mounted beneath the steering column (original box, too) and there is really just no way to mount a larger battery, anywhere.
Changing bulbs is minor, as I have a magneto system, I won't need to fool with a new coil.
old art
02-10-2007 11:37:48
can't help on gen. but hard start take the starter apart and clean out,check brushes and bearings. then clean the paint off the mounting flange and tne mount wear the starter moumts for a good connection . it willhelp for a good ground.
