Tractor Talk Discussion Forum
Water in tires
treeman
02-10-2007 15:24:28
OK I've installed a new 16.9 X 24 Goodyear turf tire and tube. Now I want to install plain water in the tube. I have access to a hose to valve stem adapter. What is proper way to install water and inflate air.I want maximum wheel weight to offset weight from front boom load. Other tire presently has water. Old tire had water.
iowa_tire_guy
02-11-2007 06:08:55
 Re: Water in tires in reply to treeman, 02-10-2007 15:24:28
There is a man here who puts water in his tires in the spring and drains it out in the fall. Just one of his chores. And yes put the stem at the top and fill the tire up to just below it. Something has to give and air is the best.
KBird
02-11-2007 06:07:29
Up here in dushore, PA we fill tires with a mixture of calcium and water and the tractor runs just fine with them on. KBird
nhboyd
02-10-2007 17:04:05
Once the water freezes, I hope the tractor isn't to rough to drive. I bought a tractor from a warm state that had water in the tires. got it home winter came and froze water took two weeks two get it thawed out.
PJBROWN
02-10-2007 17:34:38
 Re: Water in tires in reply to nhboyd, 02-10-2007 17:04:05
That sounds like you had a hell of a mess!!!!! That must of been rough!
gene bender
02-10-2007 15:41:08
Jack up the tire with stem on the top and let water run till it stops. Then you will have to realese the pressure then more water and release pressure again until it is full then it will have whatever pressure the water had when filling and you can get the tire almost completely full.
treeman
02-11-2007 05:53:52
 Re: Water in tires in reply to gene bender, 02-10-2007 15:41:08
Is it best to leave some room in the tube for air?
gene bender
02-11-2007 17:14:03
 Re: Water in tires in reply to treeman, 02-11-2007 05:53:52
You wont get all the air out anyway and when done filling you will be checking for pressure but the pressure will be close to whatever water pressure you have. Now you can just keep filling and bleeding till it just wont take any more water but there will still be a little room for air. You probably dont want too much pressure anyway so it rides fairly smooth. But you know the tire will take 20lbs easy. good luck
Glenn F.
02-10-2007 15:30:40
Treeman: I take it you do not live in Green Bay, WI. I've NEVER seena a tire with just plain water in it.
Glenn F.
treeman
02-11-2007 05:51:31
 Re: Water in tires in reply to Glenn F., 02-10-2007 15:30:40
I live in Orlando, Fl.
Sand Flat Bob
02-10-2007 17:10:38
I have run plain old water in my tractor tires for the past 15 years. Never had a problem of any kind. Of course I live about 50 miles south of Fort Worth, Texas. Sure wouldn't do this if I lived where it got extremely cold.
Bob
