Tractor Talk Discussion Forum
stuck pistons
tom kania
02-11-2007 03:07:41
have tried for 3 months to soak pistons free in a j382 continental block.pistons look like they have grown inside liners and cannot even press liners and all out.sad thing is liners look great above and below pistons.gonna take chisel to them unless you guys have better idea by sunday at noon.hate to do it but its driving me crazier than normal. help me out please.
heenk
02-11-2007 15:42:06
 Re: stuck pistons in reply to tom kania, 02-11-2007 03:07:41
I once tried different things like putting a piece of wood on it with an oil jack and a chain wrapped around the engine for a few days but it didn"t work.Then I got frusterated and used a hockey puck put on top of the piston with a piece of wood on top of that and then used a sledge hammer and some brute force and it worked.
the flying Belgian
02-11-2007 08:30:04
knock the porcalin off the spark plug drill and tap for greece zerk. make sure valves are closed fill greese gun with kerosene and pump untill the handle bends.
electro
02-11-2007 04:51:36
I know a person who used a rosebud around the top outer edge of stuck cast iron pistons. worked and piston look ok but I wonder if they were weakened.
billyar
02-11-2007 04:48:44
We freed 330ih with air, hooked air line 1 and 4 cylinders. We had removed the rocker arm to close
the valves,added 125# rocked crank it broke loose. Then we moved the air to 2&3 and turned a full rev" had it not moved we were going to hook hot water to water jacket to expand the cylinder walls.
RustyFarmall
02-11-2007 04:29:12
Won't be the first time that pistons had to come out in pieces. Seems like everyone has there own special blend or brand of penetrating oil that works for them everytime. I'm here to tell you that none of that stuff worked on a couple of engines I tore down.
BillD1
02-11-2007 05:49:56
 Re: stuck pistons in reply to RustyFarmall, 02-11-2007 04:29:12
Filling the block with boiling hot water might help. I have never had a whole lot of luck with any of the mouse milk concoctions. Usually wind up pulling the rod caps slipping the inserts out so that there is a little slack and applying a block of wood and a BFH.
fixerupper
02-11-2007 06:54:43
 Re: stuck pistons in reply to BillD1, 02-11-2007 05:49:56
The boiling water idea sounds interesting. For two years now I have been soaking a stuck F20 with every magic concoction suggested on this site and it hasn't budged yet. Jim
Tom Railsback
02-11-2007 07:53:27
 Re: stuck pistons in reply to fixerupper, 02-11-2007 06:54:43
A friend of mine used dry ice on top of the piston and it freed up in just a few minutes. The ice makes the metal shrink and come away from the sleeve.
buickanddeere
02-11-2007 12:00:10
 Re: stuck pistons in reply to Tom Railsback, 02-11-2007 07:53:27
Dry ice mixed with methyl alcohol is even colder. -126F or so if memory serves.
