Tractor Talk Discussion Forum
snowmobile
the flying Belg
02-11-2007 15:01:48
does anyone know of a forum like this for snowmobiles? got a real problem with the polairis
Leland
02-12-2007 19:05:49
 Re: snowmobile in reply to the flying Belgian, 02-11-2007 15:01:48
www.arcticchat.com
Chad Franke
02-12-2007 05:46:15
www.snowest.com, great forum, individual make forums...
Rod in Smiths Falls, ON,
02-11-2007 16:24:15
There are quite a number of vintage snowmobile sites centred around Eganville, Ontario, where they have a big festival every year.
Google "Ski-Doo Alpine", "Eganville", "forum" and you should get some hits.
juju bead
02-11-2007 16:15:32
Whats the trouble . I have had polaris for 30 years. Maybe I can help.
the flying Belgian
02-11-2007 17:35:29
 Re: snowmobile in reply to juju bead, 02-11-2007 16:15:32
juju bead,I certanly hope you can help. thanks. about 3 weeks ago I took it out for the 1st. time this season. after about 4 miles it started missing on 1 cylinder so I headed for home on remaining cylinder. got about 2 miles from home heard a pop and it died completly. It had no compression on eather cyl. Hauled it home and took off head. found piston rings had broken up on 1st. cyl and hole on top of 2nd. cyl to fail. That explains the pop noise. jugs were ok with a good honing so ordered new pistos and rings from dealer and asked him what he thinks went wrong. He sked if I had put stableizer in tank last spring. I ssaid I did. He ssked if I had put fresh gas in this year .I said I did not. He took carbs apart and determined I had 2 problims #1 the carbs had wrong jets in for my area ( so. Mn) they were to small. said people changed them to get better performance out of them. I bought the 1999 machine used in 2003. 2nd. problem was using last years gasstill in tank. So $411 later I had the thing together and it run perfect. then weather turned cold and I did not ride untill today. 25 above. This time I got 3 mi. down the road and heard the familier pop. I shut it down imedeatly and hauled it home. I have no compression on one cyl. and suspect I burned a hole in top of piston again. I have not pulled head yet to confirm. What is happoning? apairently dealers thoughts were wrong so what is it. thankyou for your interest nd I apoligise to tactor talk people for cluttering your forum with a nonrelated problem. flying belgian....
Olddog
02-12-2007 05:29:15
 Re: snowmobile in reply to the flying Belgian, 02-11-2007 17:35:29
Also check for mouse nest in the air cleaner.
davpal
02-11-2007 22:36:58
As the other guys have said, you may have a blown crank seal. Makes them run way to lean. Also might have an oil pump on the oil injection that is not working. If it were just blowing up on one side I would think crank seal, If it is blowing both sides I would think no oil.
jhill52
02-11-2007 19:21:00
Check the side crank seal on the side with the blown piston. If its bad it will let air in causing a lean mixture.
gene Dotson
02-11-2007 18:47:54
Running too lean. Need to richen up the mixture to cool down the exhaust gases. Cold air is more dense and requires more fuel. Maybe running too hot heat range plug.... Gene
SkiDoo
02-11-2007 15:25:17
Your problem is you bought a Polaris.
D17 man
02-11-2007 18:22:13
 Re: snowmobile in reply to SkiDoo, 02-11-2007 15:25:17
thats not his problem. iv'e broke down manymore times on the ski doo and never had a problem with the polaris and arctic cat. at least u got snow where u are. here in MA we got 3 inches all year
