Tractor Talk Discussion Forum
battery discharging on BS
Robert Hastrich
02-11-2007 17:01:22
I have a Briggs & Stratton L Block #422347. When you turn the key on the amp gauge is pegged to full charging. The tractor will start, it will run fine. You can disconnect the battery and it will run fine. BUT when you shut the tractor off, the battery is dead. You can put a test light on the battery and it won't even light. What's my problem??? The motor does not have an electric clutch on it. It has already been removed. The motor sis charge fine before rebuild. HELP!!
Jon Hagen
02-11-2007 17:14:10
 Re: battery discharging on BS in reply to Robert Hastrich, 02-11-2007 17:01:22
"When you turn the key on the amp gauge is pegged to full charging."
Sounds like the battery is installed(wired) backwards or charged backwards. If the battery is installed with the wrong terminal connected to ground, then the battery will discharge through the ammeter into the rectifier/regulator . Because the battery is connected backwards, the discharge through the ammeter moves the needle to the charge side although it is really discharging the battery.
Check that the battery is not connected or charged backwards. If your lucky, the rectifier and stator windings may not be damaged.
