Tractor Talk Discussion Forum
Farm implements
Walter Gorman
02-14-2007 08:09:34
Is there a good place to buy used 3 pt implements around Fayetteville NC ?
Have 52 ford...looking for disc, 4 ft bush hog, rake etc
Ultradog MN
02-14-2007 15:51:56
 Re: Farm implements in reply to Walter Gorman, 02-14-2007 08:09:34
Don't buy a 4' brush hog. You will be much happier with a 5'. 5 Foot is the same width as your rear tires so you will be able to mow right up to the outside of your tires.
Yes your tractor has enough power for it. The few times you get into some real heavy cutting you can take less than a full swath.
Buy an ORC (over running clutch) for your pto so you don't run in to the creek or the wife's car or the garage.
Walter Gorman
02-15-2007 06:24:41
 Re: Farm implements in reply to Ultradog MN, 02-14-2007 15:51:56
thanx for the advice....have a great day
Rich Va
02-14-2007 09:09:52
There's an agri-supply down the road from you in Lumberton. You can buy new stuff there almost as cheap as from farm auctions. Check your yellow pages for local tractor dealers. Also there's a farm equip. auction yard in Goldsboro and Charlotte.
Walter Gorman
02-14-2007 12:16:46
 Re: Farm implements in reply to Rich Va, 02-14-2007 09:09:52
Thanx Rich i will go take a look
